Reverse Counter Shaft Cluster Gear
  • sswaney
    • 302
    Looking for the a source for the 35703-39 Countershaft Cluster Gear.
    This is the gear used in a 3 Speed-Reverse Gearbox
    V-Twin lists it as 17-1520 but it is currently backordered.
    Did not see it available via Eastern either.
    Is anyone else manufacturing this gear?
    All help is much appreciated
    • 2044
    As far as I know,none of the special 3spd & 3+R gears are reproduced.
    I would be leery of any gear made by VTwin
    • sswaney
      • 302
      V-twin does have the Mainshaft Cluster available and in stock.
      Obviously they're sourced off shore somewhere.
      Hopefully Taiwan and not India.
      I'm a little surprised Eastern doesn't make them There's got to be some demand for them.
      Thanks for the reply Roger.
        • 4791
        I buy most of my 3&R parts off eBay. I have found NOS parts in many instances.
          • 2044
          I have an extra original mainshaft cluster & 3 countershaft shift fork assy.
          • sswaney
            • 302
            Yes, Ebay, that's usually my first move. Actually a google search of the part number generally turns up what is available.
            There is one listed currently as 35703-69 on Ebay but I believe the gear is the same. Its got the later speedometer drive gear on it.
            I communicated with the seller and its got a lot of surface rust on it. And the bearing surfaces are NG.
            I've even tried looking for a 35701-76 version with the Torrington B1212 type bearings.in place of the loose .125" bearings because I think otherwiae its the same configuration.
            Anybody know for sure about that?
            Thanks for the offer Roger. This gearbox was a 3 Speed w/Reverse already. We're still hoping to go with new parts if possible.
              • 2025
              With a minor degree of work all 1936 and up 3&R cluster gears will work in a newer application. The late clusters did remove the external snapring groove that is needed in the 36 to 38 reverse gear sets however.
              Jerry
              • sswaney
                • 302
                Following up on this. No luck locatiing the 35703-39 Cluster Gear yet.
                V-Twin is still showng it back ordered.
                I was also in need of a Mainshaft 35286-39 Mainshaft Low & Reverse gear. I ordered V-Twins mainshaft Low/Reverse gear #17-9888.
                No mention on their site that it's actually a HD part
                Received this.Not sure about that recess on inboard side on the gear
                  • 4791
                  In order to run that gear you must use the appropriate -70 mainshaft second gear as well. It has an extended center and no bronze bushing similar in design to the -59 3rd gear but with the proper tooth count for 3&R..
                  • sswaney
                    • 302
                    Thanks Robbie much appreciated.
                    Looks like that gear is 35072-70. Another one made out of unobtanium it would appear.
                    The earlier version of that gear is 35293-36 if anyone is following along.
                    V-Twin #17-9961, also Back Ordered.
                    This thing is turning into quite the rabbit hole.
