trans. case question
  • ldfly112
    • Sep 2017
    • 146
    Is the transmission case the same for a 4 speed or a 3 speed reverse
    • 4791
    What make, what model?
    • ldfly112
      • Sep 2017
      • 146
      my trans. case is a harley and has a date code 1945 it is a 4 speed
      • MMasa
        • 1192
        Yes. The case is the same. Is there a small idler gear installed in the bottom of the case?
        Mark
        Mark Masa
        www.linkcycles.com
        • ldfly112
          • Sep 2017
          • 146
          no gears yet I have a good case . Im considering a 3 speed with reverse for my 1937 UL. what are your thoughts
          • MMasa
            • 1192
            Is it a sidecar rig?
            Mark Masa
            www.linkcycles.com
              • 4791
              Are you trying to be correct for '37? The internal parts are different than later types.
                • 2025
                1937 had a RN123 shift pattern and 1939 and newer has R1N23, Mostly different gearset. Jerry
                • ldfly112
                  • Sep 2017
                  • 146
                  Yes im considering a sidecar. Where is a good source for finding the gearset and would I be better off with the 37 gearset or the 39 and newer
                    • 2025
                    I personally much prefer 4 speeds forward than 3 speeds forward with a reverse. The first year I ran a sidecar I had a reverse transmission in the bike and ditched it the 2nd year - I never had a problem finding a parking spot that I could drive out of. I have no experience riding a bike with an early reverser although I have rebuilt a few of them. I find the late reverser 'cantankerous'.
                    Jerry
                      • 2044
                      3 spd gearsets are not easy to get,early or late style.I have an extra reverse shift fork for the later style.
                      • ldfly112
                        • Sep 2017
                        • 146
                        Thanks for the advise I will be going to Wausen next month to see if i can find anything
                          • 4791
                          I have a reverse gear for the countershaft for a 36-38 box available.
                            • 2044
                            Here is a pic of the later 3spd reverse gearset
                            & my extra parts
                              • 2044
                              V Twin sells the reverse idler gear & shaft
                              The countershaft cluster gear has an R stamped on the end of high gear
