My question is there any difference from a panhead oil sending unit and ul flathead sending unit Thanks if you can help
oil pressure sending unit
yes, there are different versions for different eras,but the main difference is length of the hex to the threads is longer on OHV.Palmers book shows many of these differences
The threads are also different on newer units than early ones. Late are 1/8NPT, early are a straight thread. Don't mix them up. H-D made an adapter to use the late switch on early engines. And the 45 (WL/WLA/etc) are also the same as UL.Robbie Knight Amca #2736
