Looking to find a 7/8 x 18 left hand Die to chase threads on the transmission clutch side Main-shaft. Thought maybe there’s a OEM one out there. Thanks
VL transmission main shaft
Dear Ray, my tool and die company used to have them but is now out of stock. They estimate $500 and 6-8 weeks to manufacture a one-off, so there is a sighting shot for you.
why not use a thread file if you only need to chase them? I've saved numerous bad threads this way as well as working a nut loaded with valve lapping compound back & forth to clean up tight fitting threads.
It seems to be a bit more difficult (for me anyway) to work on (clean up) LEFT hand threads, over the much more common right. Have to keep reminding the effort to work backwards of normal if that makes any sense. Good Luck in your die search Ray. ...Smitty ......Maybe if I was left-handed.................Last edited by HDSmitty; 03-10-2023, 10:54 AM.
