Inspected the countershaft splines. All feel "distinct" ... not knife sharp, not rounded, and I don't feel any burrs or unusually sharp corners. I did notice that the fit of the countershaft into the left side case bushing is quite sloppy. Not sure if that is by design, or suggests a need to replace it.
All of the repop kicker gears I see on Ebay are very dark in color, whereas mine is bright, almost shiny. Don't know it that tells us anything. Similarly, repop cluster gears look quite dark in the photos, whereas mine is a much lighter grey (battleship grey?) color. Again, no idea if that sheds any light.
Taking a close look at the Kicker Gear, it does appear that the teeth on the sloped side are quite worn at the outer corners. Not knowing this part, I don't know how that would affect the "ratcheting". Nonetheless, looking for NOS or good used version of this, which, of course, are not easily found.
... now puzzled by the kicker spring install. If I follow the instructions per PA, (countershaft notch at 12 o'clock, spring hook at 6 o'clock to start), pulling the spring around clockwise a quarter turn to hook over the stud preloads the spring so much that it turns the countershaft clockwise to the point the notch (and thus the kicker arm) would be at about 2 o'clock after a kick (unlike what is shown in PA's photos). That takes the shaft off the tripper bolts and creates all kinds of racket and resistance when the mainshaft turns.
