Linkert M741-1 rebuild
  • #46
    "Aluminum lacquer" is what I see on contemporary blueprints, Harry!
    I use an isocyanate urethane ('secret sauce').
    A bare body is the signature of an amateur, so I couldn't do that.
    (But I "patinated" a couple on purpose. Cost extra.)
    PS: Don't forget it's a Schebler intake cover, Harry! Their levers extended opposite, outward, instead of inward to clear an air cleaner.
    PPS: It looks real hard to get at the choke disc screws (Even when the chokedisc "1" is at the top, visible if cleaned.) The detente cam ('choke shaft stop') might be off 180°?
    • #47
      Ahhh....thanks Cotten! I'm easily confused, when the cam lifts the arm the needle goes down... up is down! Oh well, so it seems I can't use this choke shaft and still have the choke action match the intake cover. I tried every which way to assemble this, and with the choke lever pointing out to the front of the carburetor the cam operates opposite of what it should be. I'll live with it... choke lever goes to the rear and where the cover says Prime all i have to remember is that it's not closed, it's fully open!
      • #48
        I beleive the choke plate is upside down.
        • #49
          Harry, I think this may have been assembled incorrect.
          Can I suggest you strip it down and start again.
          Remove lever pin and cam, rotate choke plate and shaft so hole in plate is down and screws are on the outside.
          The choke lever should now point inward. Rotate stop until it lines up with the hole in the shaft, hopefully it should now match the cover.
          With the lever in the open position, the cam should now lift up the arm and lower the low speed needle to lean out the mixture.
          If you have already tried this, I apologize, and have no other ideas.
          Cheers,
          Mick
          • #50
            If it really bothers you that much, Harry,..
            You could always get an HD# 1233-33 lever, and a 1231-33 shaft.
            Or an Indian 100193 choke lever, and a 100192 shaft. (The cam is a little different, but would probably work fine.)
            .....Cotten
            • #51
              It was buggin' me Cotten! And after Mick's suggestion I was thinking I was doing it all wrong, so last night at happy hour my wife and I had a beer with the carburetor on the table. We puzzled through it, tried four different assemblies and we still couldn't get it to match the cover....UNTIL my wife says "wait...what's wrong with the way it is? The lever angle matches up to the cover." She's right, as always!
              The cover is also stamped on the inside "DL51" and the factory correct carburetor for a 1928 101, 37c.i. is the DLX 50. I don't know if that stamping means it's for a Schebler DLX51 or not, but I'm keeping it the way it is.
              • #52
                I was thinking the same thing, but didn't know how to explain it.
                Good lick with the tuning now.
                Cheers
                • #53
                  Schebler's part number is DL50, Harry!
                  In the Service Station manual, anyway...
                  Is it cast iron/steel, or aluminum?
                  • #54
                    ...must be aluminum, not magnetic
                    • #55
                      All the real ones that crossed my benches were ferrous, Harry!
                      The only aluminum one was guaranteed repop.
                      (That doesn't mean they didn't exist, of course. But wouldn't potmetal be more likely?)
                      PS: The script apparently didn't confuse Rollie Free at Daytona '38..
                      • #56
                        Woke up to snow on the ground so I knew I wasn't going for a ride on my Chief, back to the carburetor!
                        I cleaned all the passages with pipe cleaners soaked in acetone, brushed them all repeatedly until they came out clean, then I cleaned the idle slot with a Q-tip soaked in acetone:
                        Then it was onto the float bowl and installing the float. It's not as easy as a Youtube video would lead you to think. I assembled and dis-assembled the float and needle numerous times before I got my 1/4" float height. Part of the issue was my dyslexic way of doing things... bending the float lever the wrong way once or twice. And I was fearful of breaking the float so each time I went for a new bending I removed the float from the lever. Anyway, a good day to be inside so I simply took my time and got it right:
                        • #57
                          The throttle disc I kept from the old carburetor, it does show some light but I'm hoping it's a good fit still:
                          I am curious about the throttle shaft however, I bought a new one and it doesn't fit deep into the linkage on top of the carburetor:
                          I never noticed how the old one fit, but it's the same length:
                          Am I doing something wrong or are they all like this?
                          • #58
                            That's a lot of 'daylight', Harry!
                            But it will probably 'run'.
                            Only professionals must go the extra mile.
                            • #59
                              High speed needle:
                              Low speed side:
                              So pretty much just install the plugs then mount the bowl with float.
                              I guess since this was sort of a "Frankencarb" with Schebler bowl and needles originally, I'm not surprised the throttle arm doesn't fit all the way on the throttle shaft, but it was like that before I took it all apart so hopefully it won't cause any problems! Thanks for following, especially thanks to Cotten!
                              • #60
                                Your 'throttle arm' is Schebler too, Harry!
                                Although a little longer, I'm not sure if any of their shafts ever filled the taller 'arms', actually.
                                Greer's knobs are 'signature', but certainly some of the best readily available.
                                (I like Carl's LS knobs, too.)
                                You will want a simple lock washer rather than a flat under the chokeshaft nut.
                                I'd find a smaller washer for under the cable swivel too, but only because I must.
                                The fat LS spring collar is actually 'correct' for '41-'42!
                                I have no clue why, as the rest were thin (until the HD OHV productions).
