Andrews A cam for Panhead?
  • Steve Galli
    • Nov 2019
    • 93
    Hi All
    Found an old Andrews A cam in the basement...
    Bought it new in the eighties...
    Was running this cam with shovels on the Pan lower end... Bike is going back to a panhead like it belongs...
    Can anyone shed some light for the applications this would be good for?
    I am going over my 58 FL and am wondering if it would be ok for the rebuild...
    Andrews makes an A2 cam now...
    Thank you in advance...
    Steve...
  • vph-d
    • 1088
    I've found the Andrews J cam to work well in Panheads.
    VPH-D
    • 41craig
      • Nov 2010
      • 411
      Steve; Here are a couple of old Andrews cam charts that you can use to compare your cam with others. Sorry for the crummy scans.
      • kitabel
        • Sep 2018
        • 471
        IIRC the A requires valve spring spacing, the J is a drop-in.
        The A is a nice power increase compared to the FLH.
        The Linkert Book
        • Steve Galli
          • Nov 2019
          • 93
          Craig[ATTACH=CONFIG]27035[/ATTACH][ATTACH=CONFIG]27036[/ATTACH]
          These are very helpful!! Thank you!!
          • Steve Galli
            • Nov 2019
            • 93
            Thinking the J cam is the way to go... Closest thing to stock...
            • Steve Galli
              • Nov 2019
              • 93
              VPH-D
              I think the J cam is the way to go from all the replies... Thanks!
              • govmule84
                Fat & Cranky
                • Dec 2014
                • 179
                J and A have both made me happy when in Shovels.
                If you are indeed looking for stock, I think an H grind is what you want, no?
                • Steve Galli
                  • Nov 2019
                  • 93
                  H Grind has no part number listed on Andrews web page... Is H grind cam available?
                  • pan620
                    • Oct 2016
                    • 223
                    I believe S+S has one, put one in a 71 FX and it runs nice.
                    • govmule84
                      Fat & Cranky
                      • Dec 2014
                      • 179
                      S&S makes one. Andrews or Leineweber would likely grind you one.
                      • kitabel
                        • Sep 2018
                        • 471
                        They're referring to the factory stock FLH cam.
                        The Linkert Book
                        • Steve Galli
                          • Nov 2019
                          • 93
                          That’s what I want... Hop up the FL to Stock FLH... THATS IT... ALL the hot rod stuff that’s going to happen with this bike...
                          is the J grind from Andrews equivalent to the stock FLH factory cam?
                          • vph-d
                            • 1088
                            The J cam is hotter than the stock FLH cam. I don't believe anyone makes an FLH equivalent cam, so you'll have to find a used one.
                            VPH-D
                            • Steve Galli
                              • Nov 2019
                              • 93
                              FA3E50C9-4DDE-468C-982C-042CEEF3129C.jpgHere is my used H grind cam.... is this still good to run? Looks like it’s kinda done to me...
