harley 1937 U transmission rebuilding
  • hdhikaru
    • Feb 2010
    • 217
    Hi, please advice....
    I just finished rebuilding of 37 U transmission.
    so how many cc oil should be in?
    tks
    Shin
    Shin!
    Please fill it to the bottom of the filler plug threads, level of course.
    I'll guess in the neighborhood of 630 cc.
    And please use the same oil as for the motor; Good luck!
    • hdhikaru
      • Feb 2010
      • 217
      hi Mr.Cotton, got it! thanks!!
      • hdhikaru
        • Feb 2010
        • 217
        Hi Mr,Cotton,
        I use oil single 50 for the motor. same one for the transmission too? not thicker one ... like 80 or 90?
          50 or 60. The same as you use in the engine.
          • hdhikaru
            • Feb 2010
            • 217
            ok, thanks Chris.
              Please note, Shin,
              Oil can only access the main drive gear bearings by seeping past thrust washers.
              A heavy lube would be restrictive.
              • hdhikaru
                • Feb 2010
                • 217
                got it! thanks Mr. Cotton!
