Thoughts on the best way to repair this cam case damage?
  • Green Indian
    • Apr 2014
    • 303
    What would be the best process for the repair of this cam case boss? It's from a 1942 Indian Chief.
    AMCA # 3233
    • 970
    I think I would make a fixture or use left side case to mount cover in a mill and find hole center,then remove ,weld ,remount and machine new bore.I would probably be thinking of getting a distributor also instead.
    • Green Indian
      • Apr 2014
      • 303
      Thanks Tom, that is good advice.
      AMCA # 3233
