1965-69 Big Twin clutch baskets
  • 1965-69 Big Twin clutch baskets
    Can I use a 70,s shovel head clutch basket on a 1967? i think there is a difference between late and early baskets but I don not what it is. Thanks
      Those are both "late" baskets, early is pre '65.
        They are different in the spacing of the starter ring gear.Early part #37702-65,later is 37702-70A.There is a difference in starter shafts as well.
        The clutch hub from '64 & earlier has a lip on the back & won't work on '65 & later wich has no lip to clear the inner primary bearing.
          Duffy is right, I was thinking hub, not basket.
            my first post was the same as Robbie's,hub not basket
              The ring gear on a '70 up is almost flush with the back of the basket, the '65-'69 goes further on. The machined area of the basket where the ring goes on cuts half way through the first rivet holding the plate tabs.
              Bob Rice #6738
                Thanks for the information will look around at a couple I have and see what I can do.
                  i have a dozen or so clutch baskets, probably have what you need for sale if you can't find one.
