1965-69 Big Twin clutch baskets
  • pan620
    • Oct 2016
    • 223
    Can I use a 70,s shovel head clutch basket on a 1967? i think there is a difference between late and early baskets but I don not what it is. Thanks
    • 2044
      • 4791
      Those are both "late" baskets, early is pre '65.
        • 2044
        They are different in the spacing of the starter ring gear.Early part #37702-65,later is 37702-70A.There is a difference in starter shafts as well.
        The clutch hub from '64 & earlier has a lip on the back & won't work on '65 & later wich has no lip to clear the inner primary bearing.
          • 4791
          Duffy is right, I was thinking hub, not basket.
            • 2044
            my first post was the same as Robbie's,hub not basket
            • BigLakeBob
              • 2768
              The ring gear on a '70 up is almost flush with the back of the basket, the '65-'69 goes further on. The machined area of the basket where the ring goes on cuts half way through the first rivet holding the plate tabs.
              Bob Rice #6738
              • pan620
                • Oct 2016
                • 223
                Thanks for the information will look around at a couple I have and see what I can do.
                • knucklehead 61
                  • Sep 2016
                  • 353
                  i have a dozen or so clutch baskets, probably have what you need for sale if you can't find one.
