WLA 3-speed assembly
  • DCoul
    • Jan 2016
    • 165
    Getting almost done with assembling my 3-speed and am working on Adjusting The Shifter Clutches. On page 68 it says " with the shifter cam in neutral, and the highest points on driving dogs overlapped by 1/8"...
    Are they talking about the dogs mating with the corresponding low gear by 1/8". And on the other side, the dogs slipping inside the clutch gear by 1/8"?
    Thanks All.
    • 4791
    No, they are talking about the space between the dogs and the gears being offset to each other so the dogs are therefore offset approximately 1/8" in order to get a spacing reading between them. The adjustment is the free open space between the dogs, no engagement when measuring.
    • DCoul
      • Jan 2016
      • 165
      Thanks again Rubone. I think I got it. I'll know when I can get back in there.
