Custom Reamer
  • Custom Reamer
    Does anybody know of a concern that will make custom-sized reamers or cut down a standard reamer to an offsize? I need to replace a Harley Overhead oil pump shaft bushing and will neet to ream it after pressing it in.
    Thanks....
    Bill!
    You might try http://www.aerosharp.com/aerosharp_home.htm
    But most of us would just hone it.
    (I must drive at least a dozen miles to the nearest machineshop that can grind a reamer. Are they getting rare?)
      MSC Industrial Supply has made reamers and milling cutters to my specifications in the past. Pretty reasonable folks too. Paps
      http://www1.mscdirect.com/cgi/nnsrhm
        REAMER
        Thanks for the reply. I will most likely have it honed, as I no longer have access to a sunnen hone.
        I was looking through my data and can't find the running clearance for the Harley FL oil pump drive shaft-to-bushing. Does anyone have that info.???
