Recommendation for Black Cylinders
  • wideglide38
    • Jul 2008
    • 656
    Hi,
    I have a friend who has a '91 FXR and is planning a base gasket replacement. While the cylinders are off, they wanted them re-painted (Harley had engine paint flaking issues I believe between '91-'94). They want to stay with flat, wrinkle black since are not pulling their motor. Does anyone know of a good painter/shop or suggestions?
    William
    William Edwards, AMCA #10035
    • 5998
    You might want to talk to someone at an automotive paint store. I've been given very good advice by people behind the counters as many of them have been in every part of the automotive fefinishing business.
    • vph-d
      • 1081
      Does the factory offer the paint you need?
      VPH-D
      • wideglide38
        • Jul 2008
        • 656
        Eric - I will quiz a couple of quality industrial paint stores in town. They are looking for someone to shot the paint! (I'm no painter. )
        VPH-D - Good suggestion. I'll contact a friend who works in my local dealer's service dept.!
          • 5998
          A good paint job is all about surface preparation, and you would probably be more motivated to get that right than anyone else William. After all the misery of getting the preparation right, painting is the fun part.
          • wideglide38
            • Jul 2008
            • 656
            Eric, I agree that well done work is all about the preparation. If this were my scoot, I'd certainly tackle the work cuz I'm a tight-wad. Haha!
              • 2029
              That wrinkle black peeled very bad and as far as I know was discontinued long ago.You had to paint the cylinders very warm[95degF]to get it to wrinkle.I have not found wrinkle black for a while and use flat/not gloss on those motors
              • jim d
                • Sep 2010
                • 279
                I always used a wrinkle paint from a automotive speed or custom supply house. Tape up well using duct tape to protect the cylinder walls. Plug any holes and glass bead the outside. Blow off well and wash them a few times in hot soapy water, clean any threaded holes you can't get them too clean. Blow off the water awhile they are still warm or put them in a oven 150-175 degrees. Tape areas not to be painted. Set them on a board to paint or hang them. You can a put bolt or wire into the head hole as a handle sticking out the top. When painted awhile wet transfer to a warm oven 150-175 degrees. Do not believe the can that it will wrinkle without the oven, sometimes it dose sometimes it dose not. Keep checking and remove when wrinkled. The paint will still be soft when warm it will become hard over night.
                Jim D
                Jim D
                  • 2029
                  Googled it ,VHT makes Black wrinkle-never saw it locally when looking.I agree with your methods,I only had luck with very warm cylinders
                  • painterdale
                    • Oct 2013
                    • 422
                    The VHT REALLY stinks when it gets hot. Heating the part first, painting, then using a heat gun outside works pretty good. Especially if the only oven is in the kitchen! Dale
                    • wideglide38
                      • Jul 2008
                      • 656
                      Thanks Gents for all the great advise and suggestions.
                      William
                      • jim d
                        • Sep 2010
                        • 279
                        VHT is the paint that I used most of the time. I have been known to use the kitchen oven a few times but have graduated to my own shop oven in more recent years. If you do a search for Farberware Turbo ovens they can be purchased for $25-$50 on Craigslist. They are an older convection oven that was for counter top use in the home and were well built, good for about 500 degrees and light enough to move around with ease.
                        Jim D
                        Jim D
                          • 5998
                          I keep forgetting about those counter top ovens that were so popular back in the 70s, and 80s. There are a lot of jobs they could be handy for. Thanks for the tip Jim, I'll start looking.
                            • 8229
                            Good luck Eric,
                            I have been searching the alleys for years (even before the Great Garbage Crash of '08) to replace the large one that an associate used to detonate a rattlecan of paint (back about '94 or so. He soon left to work at the Dealership...)
                            A little fudging got the elements to heat again, and I put a sheet of aluminum in place of the window, but the controls were sacrificed.
                            Thankfully, infra-red thermometers got cheap.
