HD bearing cages- when to replace?
  • DanM
    • May 2005
    • 465
    Generally speaking, when you you guys reuse or replace the bearing cages in the HD lower end during a rebuild?
    Dan Margolien
    Www.yankeechapter.org
    Pocketvalve@gmail.com
    Very good question, Dan!
    Horribly worn cages should be pitched of course,
    but most are re-used without any sudden destruction, so ignored.
    It would be ideal that all used cages are re-Parkerized, for retaining lube for start-ups after sitting for extended periods.
    • DanM
      • May 2005
      • 465
      THX Tom. I wasn't sure how well the cages are intended to locate the rollers, and sometimes I see the edges are worn away. But for the few engines I've done I've replaced and reused. doing another JD and it got me to wondering this time around cuz they were not so "horrible"......
      Dan
      Dan Margolien
        I made a new batch of the 301-15 crankpin roller cages 1915-36 because the used ones were getting so rough. I don't think any of the parts companies have done them yet. Also made 3922-30 the VL wheel hub and rear brake roller cage.
        • Carl Olsen
          • Jan 2002
          • 261
          We make the cages for the 36-54 sprocket and pinion bearings for pans, knuckles and flatheads.
          Carl
