Trans/speedo ratio??
  • harley1
    • May 2010
    • 74
    Hi All,
    Wondering what year and speedo ratio my trans is. 1:1 or 2:1. Numbers on trans are 34703 65.
    Thanks!
    • 4791
    That number means nothing in regard to speedo ratios. The gearing changed in '68, what year is the gearbox? The number you posted is common to both ratio type gearboxes.
      • 4791
      Pull the gear for the speedo cable and post a picture. They can be identified by number of teeth and pitch profile.
      • harley1
        • May 2010
        • 74
        Thanks Rubone, I will try to get to it this week. What does the N87721 represent?
          • 4791
          Is it stamped on the right upper front of the case? If so it is a code that directly ties it to a certain VIN number. Commonly referred to as anti-theft codes. If that is where it is it will identify a time frame,not an exact year, but close. Did it originally come with your bike? If not just be aware that if it came from a bike reported stolen it can be traced to that bike. An "N" prefix number is likely '69, but without history of where it came from or what is inside it the best thing is still a picture.
