Date codes
  • kg993
    • 263
    Date codes
    Someone wants to buy a -9 pan cylinder. That got me going again searching for answers on the codes. Where can I find some sort of list explaining what the letters and numbers mean? Same info needed for heads-trans cases-covers-ect.
    Also I have some cylinders with no markings and am 99% sure they are OEM, is that possible?
    Kerry
    Kerry AMCA # 15911
  • kg993
    • 263
    OK I just got another set of cylinders. Rear has no marks and ft., I believe is K 26-0.
    Kerry
    Kerry AMCA # 15911
      • 5947
      K 26 0 October 26, 1950
      • kg993
        • 263
        OK so does that mean December is A- Jan B- ect.? But how do you know if it's 1950 or 1960? And were there random year cylinders that had no marks?
        Thanks, Kerry
        Kerry AMCA # 15911
        • kg993
          • 263
          I went back and verified that the K 26-0 I have does have a return hole drilled inside the bore, and it's too nice to have been done with a hand drill.
          Kerry
          Kerry AMCA # 15911
          • diesel55
            • Jul 2011
            • 262
            hello check where the oil return hole is. bottom early/ late in side.
            • kg993
              • 263
              Drilled inside of bore.
              Kerry
              Kerry AMCA # 15911
                • 5947
                Thanks, Kerry
                Jaunary is A. I is often not used. 1960 would have a different numbering system.
                • kg993
                  • 263
                  Ok, so why does this cyl. have the 53-up return hole? Hate to keep asking questions but I can't make any sense out of the code except that A-M = months and the first #'s = a day date and possibly the last # = the last digit in a certain decade. How do you tell what decade the part was made in?
                  Kerry
                  Kerry AMCA # 15911
                    • 5947
                    Could it be a replacement part cast in 1960.
