Float Adjustment
  • indianut
    • Feb 2005
    • 308
    Float Adjustment
    Could someone suggest a proper float adjustment when using a Scheb DLX float bowl with the Eliptical float on a 1 1/4" Linkert carb? Thanks!
    http://laughingindian.com/
    A.M.C.A. Member Since 1986
  • Tommo
    • Sep 2001
    • 1321
    Factory setting for ALL Deluxe carbs is 7/16
    Peter Thomson, a.k.a. Tommo
    A.M.C.A. # 2777
      Tommo!
      Certainly all bronze bowl DLX's are 7/16",..
      but bending a "tin-top" potmetal DLX bowl's lever that low is beyond its limits, and makes the float interfere with the bowlstem.
      Have you any literature for the potmetal DLX's up through '39?
      (The 1940 DLX literature specifies 1/4", corresponding to their unique Linkert-shaped float. That seems high for the earlier design.)
      Thanks in advance,
