magneto
  • mootch
    Mootch
    • Oct 2009
    • 46
    magneto
    thinking of running a magneto on my 45,anyone have any bad experience with that,also if someone has a simple wiring diagram it would be helpful.....real basic,no flashers......
    • 5950
    • Sargehere
      Member since 1972
      • Jul 2006
      • 971
      That is an old Easyriders points-and-condenser wiring diagram. You axed for magneto. All you need to do is ignore all the wiring following off the ignition sw. to the coil. You run a ground wire off the side of (I presume) your Fairbanks-Morse dash-58 ("short stub") Sportster magneto, to any of a variety of places. Simplest is a piece of flat "spring steel," like a feeler gauge blade, screwed on the (insulated) grounding post on the magneto but not touching anything. You're always "on." Press the steel blade against the magneto body to ground it to stop the engine. Next step would be a wire to a push button sw. to ground somewhere. Fanciest would be to a second stock horn button installed on your handlebar, opposite side from the real horn button, but just like it.
      This is all in addition to the key switch, which should be in the side of your Fairbanks-Morse magneto. Turn it on, kick over the bike, turn it off and the bike stops.
      Ive run the F-M magneto occasionally in my U-models. Same set up, same adapting parts as in 45s or Ironhead Sportsters. If you have a short-stub F-M magneto with the mechanical tach drive in its base, you can have an adventure hunting up the original Sportster tach and cable, and drive unit. (IF the driving gear on the magneto isn't shot from wear, as most of them are).
      Gerry Lyons #607
      http://www.37ul.com/
      • rwm
        • Dec 2006
        • 1302
        put the magneto where the timmer was and run 2 wires from the top holes in the mag to your spark plugs
        rob ronky #10507
        www.diamondhorsevalley.com
        • gary.h
          • Apr 2009
          • 176
          im running a wico on my 45" if you want some pics of my set up let me know.
          • indianut
            • Feb 2005
            • 308
            I have run a mag on my 45 for 20+ years with no capacitor or battery eliminator. A 12 V gen with a Bosch Reg. I have mine set up with the stock ign switch where you turn it to on it completes the (ground) circuit and it kills the mag! Works great. When the Engine starts, the lights come on. Every once in a while when I come back to my bike the switch has been turned to the OFF position, by a Good Samaritan! Then I am ready to Kick!
            http://laughingindian.com/
            A.M.C.A. Member Since 1986
            • mootch
              Mootch
              • Oct 2009
              • 46
              No Battery
              i have absolutely no knowledge about wiring....i would like to know if someone can send me a 12V wiring diagram for a 45 with a magneto and NO BATTERY !!!! is it possible ?????
              • Sargehere
                Member since 1972
                • Jul 2006
                • 971
                That's probably going to be difficult to explain if you "know absolutely nothing about wiring," Mootch.
                Indianut, up above brought that possibility up. If I remember correctly: There's a deal that uses a large capacitor to allow the power the magneto is putting out to illuminate very limited number of lights (very poor: lights, despite the capacitor [acts as an electrical "moderator" in circuit] go up and down, up and down), depending on how fast or slow the motor's running. The "Battery Eliminator" is another beast, that lets you use a stock generator, but same way, lights go up and down.
                Indianut, I hope will chime in here. I haven't fooled with these things for over 35 years, when they were "all the rage," during the chopper craze.
                Gerry Lyons #607
                • mootch
                  Mootch
                  • Oct 2009
                  • 46
                  i don't mind about my lights flickering low at a light................
                  • mootch
                    Mootch
                    • Oct 2009
                    • 46
                    can i get the diagram please...................
                    • mootch
                      Mootch
                      • Oct 2009
                      • 46
                      i wanna run headlight ,tailight no horn with a magneto and no battery....if you got a diagram i would appreciate it....
                      • Sargehere
                        Member since 1972
                        • Jul 2006
                        • 971
                        Hi, again, Mootch,
                        Here's a whole discussion of Sportsters with magnetos and Battery Eliminators and stock capacitors, right here in the forum. (Gained by typing a few key words into "Search" above):
                        http://www.antiquemotorcycle.org/bbo...ator#post72925
                        Note these:
                        "Would also like to point out that your '65 is a 12V and the '64 would be a 6V. In speaking with my friend again, he referred me to Shop Dope #347, dated Sept-54, as the only wiring he was aware of for 6V Sportsters and K-models without a battery." - Brian Howard
                        The (stock CH magneto Sportster capacitor's) part number was 32727-63" - contributed by VPH-D
                        And: "Google the part number. There as several references/links to it." - contributed by Bill Gilbert in Oregon
                        I hope this puts you on the right path. Old H-D factory update bulletins, sent to dealers and called "Shop Dopes," are reprinted. Antique Cycle Supply published "Service Shop Dope Volume III" which contains Shop Dope #347. Do you have a library card, Mootch? From your local library, I mean, wherever you live. With just that little passport to knowledge, you can order an interlibrary loan from the Dayton Metro Library (Ohio) of "Service Shop Dope Volume III", which has a copy of it "on the shelf." All that took about 10 minutes to find, on Google.
                        Hope this helps!
                        Gerry Lyons #607
                          I agree. I bin running that set up on my 60FLH for twenty years. I have a micro momentary switch on my dash that grounds the mag. I have a Porko oil tank with out a battery pit. Between that, oil cooler and my oil filter I got about six quarts of oil. Lights at idle? I practically don’t have any but the trade off has been worth it. Got rid of the belt and put in the mag and I’ve never been stuck since. I’ve bin playing with the idea of putting back in the battery and getting one of those alternators that fit in the generator hole. Imagine being able to run a halogen head light full steam. Bob L
