horn...dead battery
  • cscott
    • Oct 2002
    • 451
    horn...dead battery
    i was working on a pancake horn off the bike and i had a 6 volt battery for testing, after a while of horn testing the charged battery just died???
  • DEEBS47Chief1991
    Living The Dream
    • Jan 2023
    • 1256
    Yes. Other than an electric starter (which only applies to most 12V bikes), the horn takes the most current to operate on a motorcycle. It's basically a solid coil of wire from positive to negative volts to form an electromagnet. Once it pulls in one direction a set of points releases the hold of the electro magnet and it returns (under spring pressure) to it's normal position. At that point it re-energizes and this opening and closing of the circuit very quickly causes a high frequency sound that can be heard as a horn blaring.
    Long story - short, yes, it will drain your battery rather quickly. Just re-charge it after your testing.
    • DEEBS47Chief1991
      Living The Dream
      • Jan 2023
      • 1256
      Some more information on horns:
