Circuit Breaker Points and Condensers
  • Iacovos
    • May 2012
    • 208
    Hello everyone.
    Which points and condensers are mostly used nowadays especially with many of them manufactured in the Far East now?
    Have not come across this before and now need to change them on my 64 FLH.
    Any input is greatly appreciated
    THANKS
  • dukekleman
    • Jul 2022
    • 595
    Lacovos,
    I use "Standard" brand and/or "Blue streak" series offered were available.
    I have recently noticed a running production material change on inventory of the "Blue streak" series point and condenser service kits.
    Duke
    • Iacovos
      • May 2012
      • 208
      Originally posted by dukekleman View Post
      Lacovos,
      Duke
      Thanks Duke
      Pulled out mine off the bike and both say Delco Remy Made in USA...so not sure how many years they are in there
      Since I am rewiring it is a good opportunity to change both points and condensers
      • BigLakeBob
        • 2766
        Napa points CS2350
        Condenser RR174, or RR177 (longer wire)
        Made in Mexico now.
        Bob Rice #6738
        • Iacovos
          • May 2012
          • 208
          Originally posted by BigLakeBob View Post
          Napa points CS2350
          Made in Mexico now.
          THANKS BigLakeBob
          • otis71
            • Jul 2015
            • 594
            OEM points for Panhead’s can still be found if you look a little. Probably your best bet. I believe HD dealers still have the condensers, if they are obsolete it has not been real long so they should be available too. I guess you need two sets for the dual point set up on a 64.
            • chuckthebeatertruck
              • Jun 2018
              • 691
              At present, there are no contact breaker points manufactured in the USA that I am aware of. Even seeing "made in USA" may not be what you think. There are several loop holes in US trade laws for items like this which allow for components made in say Taiwan to be put together in a free port and labeled as "made in USA" though not a single component is US in origin.
              For the "Far East" made sets; the contact material is not the issue. The points themselves wear about the same as anything else I've used over the past 40 years. Instead, the challenge is the rubbing blocks. They often wear at a rate that is way, way more noticeable than points from 40 years ago. This isn't relegated to just "far east" points; I recently had a set of genuine Marelli points supposedly made in the EU with the exact same problem. What happens is that instead of getting 5-6K miles between gap adjustments, you get anywhere between 1000 and 3000 miles between gap adjustments.
              I've had the best luck lately with NOS point sets that I bought in bulk from the Dixie/Superior close outs. These are all Taiwan points, but from 30+ years ago and the quality is higher than today. I've had no issues with these points and the set with the highest mileage is at circa 16K and has only been regapped once at circa 9K miles. All the other bikes running these have 3-5K miles on them and have had no maintenance and have created no fuss.
              Anyways, the challenges with the point quality is because no HD has used points in more than 40 years and the last vehicles to still have points also phased out between 1985 and 1990. This means that as vehicles aged off the road; demand for daily driver points dried up. Folks weren't buying points for vehicles used 10-15K miles a year and the makers wanted to cut costs on lower demand parts, so lower quality materials made their way into manufacturing. Today, not too many people use their old iron enough to complain about rapid wear -- so there's no reason for manufacturers to improve the product. We therefore now get parts that "work" but don't last nearly as long as their predecessors.
              Now, if you want to go hunting NOS, be advised that all 250, and 292 General Motors inline six cylinder motors made between about 1954 and 1980 used a condensor which is a match in capacitance to the HD condensor and just a wee bit physically larger (1/32 or so in diameter and 1/16th or so longer). I have used them in big twin auto timers, ironhead sportster auto times, and manual timers for both big twin and XL sportster. You can get them brand new from the auto store -- but all of them over the counter today are made in Mexico (most common) or Taiwan (less common).
              • Peter Cooke
                • Aug 2012
                • 569
                Someone posted a while back that they'd purchased, and were happy with, one of these.
                thorcap.com
                • Iacovos
                  • May 2012
                  • 208
                  Thank you for all your detailed replies, based on your experiences!
                  otis71 correct dual points and condensers for the 64
                  chuckthebeatertruck completely agree with you. The “made in …” would not had been an issue if all aspects of the components performed like in the past
                  I am attaching a picture of the condensers i took our from the 64FLH.
                  Printed on Delco Remy Made in USA
                  Nostalgic
                  • DEEBS47Chief1991
                    Living The Dream
                    • Jan 2023
                    • 1256
                    This may have been done before on the forum but here is a valuable upgrade to your points/condenser if you decide to keep them and not go to a Hall effect sensor (electronic ignition). The quality of condensers today is poor at best. In the past 30 years I have had 2 fail in my 47 Chief (both on the way to the Yankee meet in
                    • Iacovos
                      • May 2012
                      • 208
                      Thank you!! Well structured instructions!
                      • otis71
                        • Jul 2015
                        • 594
                        I put a quick start 2000 in my ULH because oem early style points are expensive if they can be found. Haven’t had any problems with it and nothing gets altered. Only visible difference is an extra wire going to the coil. He makes them for dual point timers too.
                        • Iacovos
                          • May 2012
                          • 208
                          Thank you otis71
                          Will have a look
                          i believe this is the website
                          • PRG
                            • Nov 2006
                            • 612
                            Howdy sir,
                            If converted to two brush and electronic regulator you can dispense with that extra coil wire for a totally stock appearance. Same applies to the generator wiring layout. Click at my link below.
                            Ed's signal device comes with 3 wires, one red (positive) which derives power from the ignition switch, a ring connectored unit ground and a black wire runningto the negative side of the coil. He advises to run the red wire (in vintage cotten sheath provided) to the positive side of the coil (front containing two wires) and the black signal wire to the back terminal. I wanted this installation to be entirely concealed. When converting to two brush/electronic regulator one now has a wire freed up with a terminal at the light switch post on the ignition switch and a terminal that once resided on the switched terminal on the generator. ON 46-earlier simply move the wire from terminal 4 (lights) to terminal 5 (key on power) at the ignition switch then route the wire at the generator end under the distibutor to an insulated post as seen above. This will now provide a switched power source to run the unit.
                            Cheerio,
                            Peter
                            #6510
                            • otis71
                              • Jul 2015
                              • 594
                              I replaced the supplied synthetic covered wire with cloth wire and ran them through a single cloth loom making the extra wire almost unnoticeable. In hindsight sight I could have spliced the two wires inside the loom making it completely unnoticeable. Maybe add that to my “to do list”.
