I'm thinking to put an inline fuse from my battery to the battery wire on my 1946 Indian. What size FUSE should I put inline? Only running a headlight, fender light, Speedo light, and tail light. Nothing "extra".
Fuse size to use?
You should size the fuse to gauge of the wires behind it. 15A is probably best, but I don't know what you are running.AMCA #41287
1971 Sprint SS350 project
1972 FX Boattail Night Train
1972 Sportster project
1973 HD Golf Cart project
1989 Springer Softail project
2020 Heritage Classic 114
- 1 like
Nice! Thanks for the info! I found a wire that's bare just at the handlebar hole. Which led me to think I BETTER put a fuse on it!Originally posted by motor-officer View PostI have run a 10 amp on mine for years with no problem.
Jim
AMCA #6520
There you go Jim... if you blow a fuse, any fuse... its probably a wire thats gone bare or in some other way compromised, (pinched,or broken, and touching the metal frame or other component.
a higher rated fuse usually means the wire that is faulty has more heat and time to mess things up in a much fashion... like burning up the whole harness !!
Good on you for finding the problem, before its too late !!
Roger
- 1 like
Typically I run a 20 amp fuse.
If you have a Amp clamp or a DVOM you can measure your amp draw at the battery with all things applied (Headlight High beam, speedo/dash bash, running tail light w/brake light illuminated.
This is quick and easier than calculating the math on all items individually. Very accurate in the end.
- 1 like
I put inline fuses in all my Harley big twins. I use 30 amp fuses. Least little touch working on it (sometimes forget to remove fuse before doing something) and it blows instantly. I think the bigger fuse might be a little more vibration resistant. Vintage triumph service manuals call for 30 amp fuses and they only charge around 4 amps.
- 1 like
Originally posted by otis71 View PostI put inline fuses in all my Harley big twins. I use 30 amp fuses. Least little touch working on it (sometimes forget to remove fuse before doing something) and it blows instantly. I think the bigger fuse might be a little more vibration resistant. Vintage triumph service manuals call for 30 amp fuses and they only charge around 4 amps.
Good info about the Vintage Triumph using a 30A! Thanks I just looked at the wire diagram for my 1965 Honda CB160 and that shows a 15A fuse.Last edited by Jim; 12-20-2023, 06:56 AM.Jim
AMCA #6520
