I'm thinking to put an inline fuse from my battery to the battery wire on my 1946 Indian. What size FUSE should I put inline? Only running a headlight, fender light, Speedo light, and tail light. Nothing "extra".
Fuse size to use?
You should size the fuse to gauge of the wires behind it. 15A is probably best, but I don't know what you are running.AMCA #41287
1971 Sprint SS350 project
1972 FX Boattail Night Train
1972 Sportster project
1973 HD Golf Cart project
1989 Springer Softail project
2020 Heritage Classic 114
Nice! Thanks for the info! I found a wire that's bare just at the handlebar hole. Which led me to think I BETTER put a fuse on it!Originally posted by motor-officer View PostI have run a 10 amp on mine for years with no problem.
Jim
AMCA #6520
There you go Jim... if you blow a fuse, any fuse... its probably a wire thats gone bare or in some other way compromised, (pinched,or broken, and touching the metal frame or other component.
a higher rated fuse usually means the wire that is faulty has more heat and time to mess things up in a much fashion... like burning up the whole harness !!
Good on you for finding the problem, before its too late !!
Roger
Typically I run a 20 amp fuse.
If you have a Amp clamp or a DVOM you can measure your amp draw at the battery with all things applied (Headlight High beam, speedo/dash bash, running tail light w/brake light illuminated.
This is quick and easier than calculating the math on all items individually. Very accurate in the end.
I put inline fuses in all my Harley big twins. I use 30 amp fuses. Least little touch working on it (sometimes forget to remove fuse before doing something) and it blows instantly. I think the bigger fuse might be a little more vibration resistant. Vintage triumph service manuals call for 30 amp fuses and they only charge around 4 amps.
Originally posted by otis71 View PostI put inline fuses in all my Harley big twins. I use 30 amp fuses. Least little touch working on it (sometimes forget to remove fuse before doing something) and it blows instantly. I think the bigger fuse might be a little more vibration resistant. Vintage triumph service manuals call for 30 amp fuses and they only charge around 4 amps.
Good info about the Vintage Triumph using a 30A! Thanks I just looked at the wire diagram for my 1965 Honda CB160 and that shows a 15A fuse.Last edited by Jim; 12-20-2023, 06:56 AM.Jim
AMCA #6520
