Spark Plugs
  • 1970 XLCH
    • Nov 2010
    • 177
    Spark Plugs
    Hi Guys , me again . I've been using Champion J12YC plugs in my "49 Pan ( 74 cu in , 6 volt ) forever . Just wondering if there is anything better out there ? Thanks, Mike
    Gadfly from the Dumpster
    • 8229
    Trick question, Mike?
    If both plug brands fire, how you going to know if one fires "better"?
    A dyno I guess?
    • Rubone
      • Aug 2004
      • 4773
      Champion built plugs for H-D for decades, they were identical to OEM except for the knurlinng pattern. Many folks have their own favorites, AC, NGK, Bosch, Autolite, etc. The only thing I can tell you is try others that interchange and see if you notice a "seat of the pants" difference.
      So what oil do you use??
      • JoJo357
        • Feb 2016
        • 3255
        I run splitfire plugs Mike. You can definitely feel the difference from a performance aspect. Seems to start easier also. When i used to feel frisky, i would index the plugs~this always worked on any plug. Good Luck.
        *M.A.D.*
        • 1970 XLCH
          • Nov 2010
          • 177
          Thanks guys ! Not a trick question , Cotton . I run 60 wt. Harley Oil
            • 8229
            If you run harley oil, Mike,...
            You might as well run harley plugs.
            Originally posted by JoJo357 View Post
            ..Seems to start easier also...
            If a bike always starts with one primed kick, M.A.D.,..
            How will you know if a trick plug makes it start easier?
