Hi Guys , me again . I've been using Champion J12YC plugs in my "49 Pan ( 74 cu in , 6 volt ) forever . Just wondering if there is anything better out there ? Thanks, Mike
Spark Plugs
Trick question, Mike?Originally posted by 1970 XLCH View PostHi Guys , me again . I've been using Champion J12YC plugs in my "49 Pan ( 74 cu in , 6 volt ) forever . Just wondering if there is anything better out there ? Thanks, Mike
If both plug brands fire, how you going to know if one fires "better"?
A dyno I guess?
Champion built plugs for H-D for decades, they were identical to OEM except for the knurlinng pattern. Many folks have their own favorites, AC, NGK, Bosch, Autolite, etc. The only thing I can tell you is try others that interchange and see if you notice a "seat of the pants" difference.Originally posted by 1970 XLCH View PostHi Guys , me again . I've been using Champion J12YC plugs in my "49 Pan ( 74 cu in , 6 volt ) forever . Just wondering if there is anything better out there ? Thanks, Mike
So what oil do you use??
DCP_2787.JPGRobbie Knight Amca #2736
I run splitfire plugs Mike. You can definitely feel the difference from a performance aspect. Seems to start easier also. When i used to feel frisky, i would index the plugs~this always worked on any plug. Good Luck.Originally posted by 1970 XLCH View PostHi Guys , me again . I've been using Champion J12YC plugs in my "49 Pan ( 74 cu in , 6 volt ) forever . Just wondering if there is anything better out there ? Thanks, Mike
*M.A.D.*Last edited by JoJo357; 10-26-2022, 02:58 AM.
If you run harley oil, Mike,...Originally posted by 1970 XLCH View PostThanks guys ! Not a trick question , Cotton . I run 60 wt. Harley Oil
You might as well run harley plugs.
If a bike always starts with one primed kick, M.A.D.,..Originally posted by JoJo357 View Post..Seems to start easier also...
How will you know if a trick plug makes it start easier?
....CottenLast edited by T. Cotten; 10-26-2022, 02:54 PM.AMCA #776
