Coil Rebuild
  • Temple
    • Nov 2014
    • 97
    Coil Rebuild
    I would like to have my 1948 panhead coil rebuilt for 6v. Who are my options? Thanks for the help.
  • Steve Swan
    Possessed by Motorcycles
    • Aug 2013
    • 1589
    fwiw, i replaced the dead internals from a repro JD coil with an Australian Tri-Spark with condensor, both fit perfectly inside. The nice thing about the Tri-Spark is the ht wires unscrew, so you can use your choice of wires. https://www.trispark.com.au/Dual-Lead-6V-Ignition-Coil
    Steve Swan
    27JD 11090 Restored
    27JD 13514 aka "Frank"
      • 8234
      Before you throw money at it, Temple,...
      Please set it upright, and warm it with a heat lamp until the remains of any plug wires can be pulled out easily.
      Let the coil cool, and take plastic soda straws and push them into the potting compound to pull out plugs where the wires go (one is usually deeper than the other).
      Cram new wires in until they bottom out, and try it. You have little to lose, and often they work better than a repop!
      • Temple
        • Nov 2014
        • 97
        I will give that a go. There was someone who said they would rebuild it for me on the American Iron Forum. I saved the information but can't find it now. T-bonez or something like that was the user name. I will give this a go but was looking for a solid backup for long trips. Thanks Cotten.
          • 8234
          If it was "T-Bone" Tom Brewer of Bone-A-Fide Cycle, Temple,..
          He has passed away, and will be missed.
          • Temple
            • Nov 2014
            • 97
            Sorry. Yes. That is the name I remember.
            • Rollo
              • Nov 2008
              • 599
              Try Rat at Harbor Vintage. He was doing them. Not sure f he still is but know a few who used him and worked out fine.
              Tom (Rollo) Hardy
              AMCA #12766
                • 8234
                As an aside, Folks,...
                Does anyone have an educated guess as to what the original potting compound might have been?
                I don't really need to know, but posterity might find it interesting,
                Thanks in advance,
                • paddy
                  • Apr 2014
                  • 219
                  Jeff Goorman is building 6v and 12 volt coils with exellant sucess. And they are dead balls on. better than my spellin. he is on facebook and his email is bulldogbrothersgarage@gmail.com I own 3 of them with no problems
                  • sw48
                    • May 2022
                    • 40
                    Dave at Harbor Vintage does still rebuild vintage coils. He just did two -48 style panhead and one knucklehead 6V coils for me.
                    • Temple
                      • Nov 2014
                      • 97
                      Thank you.
