Panhead Ignition switch assembly
  • 54Police74
    • Jun 2012
    • 13
    I have taken my ignition switch apart for cleaning and have found myself unable to reassemble correctly. I have factory, Bruce Palmer, Clymer, and Rick Schunk manuals. Could a member give me some insight on reassembly, the mechanical portion is easy however the switch operation has become an issue. The switch correctly assembled will allow me to start wiring with replacement wiring harness.
    • 8234
    Chances are, 54Police74,...
    Is that all you had to do was grab some needlenose pliers and rotate the contact bar to where it wasn't worn.
    (But with Clymer and other classical mis-information, I can only remind you of the axiom: If its taken apart,... It's broken.)
    The '41 and later 45" Service Manual has far better switch info than any OHV literature that I am aware of; It may be in the AMCA library, maybe. Good luck!
    .....Cotten
      • 8234
      Well I gave up on adding scans to my last post, Folks,...
      So here I try again...
        • 4785
        The problem with this info is it is for a WLA switch which has many parts not used in civilian switches and can merely add to the confusion for someone unfamiliar with the differences.
          • 8234
          You got anything better, Rubone?
          .....Cotten
            • 4785
            • 54Police74
              • Jun 2012
              • 13
              Thank You T. Cotten and Rubone for the provided information. This morning I realized that the key only locks and unlocks the switch, I was trying to operate the switch function with the key. At 71 years old mistakes can seem so foolish! I will add the provided info to my 54 rebuild history note book.
                • 8234
                I applaud you for your effort, Rubone!
                But can you add any text?
                Posterity needs it most, Thanks,..
                • Architect
                  • Dec 2014
                  • 283
                  I had my ignition switch apart on my 1970 FLH this week. No keys when I bought the bike, though an original switch (it appears). Anyway I found a NOS tumbler with keys and pulled her all apart for installation and cleaning. Oh boy did she need a good cleaning. Reassembly became a thing, but the third assembled picture from Robbie showed me how the tumbler engaged the lock plate, and then we were golden. Nice to have a locking switch.
                  Thanks again to the Forum for providing useful and important information.
                    • 5952
                    Any key will work in a Panhead era switch. A true Panhead switch won't have a key code next to the keyhole.
