6v Delco Remy diaphragm horn rebuild.
  • Joseph.Greiner
    • Mar 2014
    • 16
    I was testing the electrical components of my fathers 35 VLD and found that the horn didn't work. I took a few measurements and discovered the horn had an internal resistance, between the posts, of almost 200k Ohms. A little out of the range of less than 0.5 Ohm recommended by Perry Ruiter.
    I started with dis-assembly, fairly straight forward, 11/32" wrench or socket, except I have one nut on my horn that is 3/8", I will have to correct that later. At this time I also discovered that someone has been in here before, with a sand blaster. Crossed fingers in hope the coil isn't damaged.
    I pulled the air gap screw out because I didn't research before taking the horn apart. There is no specification that I could find for this, so on assembly there was a bit of trial and error before getting it correct.
    After removing the cover and diaphragm I cleaned the points with some emery paper and checked the resistance between the posts:
    Still quite high. So I tested the components, starting with one post and moved throughout the horn until I found the problem. In this horn it turned out to be the other post itself!
    I am not sure if the bare wires at the posts should be as long as they are, but the extra length was nice and handy for testing.
    After some fiddling with the post insulator material, removal without total destruction, I managed to get the post out and found the source of my high resistance.
    Some nice corrosion on that post! I am surprised that the wire was just wrapped around the post, no solder, nothing to give it a good mechanical connection. I am not sure if that is how they were made, or if it was something done during its previous cleaning and re-assembly.
    After cleaning up the post, I soldered a loop onto the end of the wire for the coil, then soldered the loop to the post. A little dab of silicone around the insulator at the post hole in the housing to keep water out. Assembled the post into the horn, re-using the insulating paper and rechecked my resistance.
    Hooray, less than 0.5 Ohms!
    I assembled the diaphragm and ringer disc onto the front of the horn, setting the air gap screw to 2 turns out from touching the coil core. Then I adjusted the points adjuster so it was showing continuity when the diaphragm was not pressed, and open (infinite) when pressed with my thumbs. After a few adjustments it ended up sounding like this: https://plus.google.com/photos/10391...30323496803031.
    My air gap ended up at 1 full turn out from just touching the coil core. Your mileage may vary. Also there is a metal post built onto the back of the diaphragm, this must be assembled so this is over the points so they are pushed apart when the coil is active.
    I hope this helps some folks out there. If I have made any mistakes please let me know.
    -Joe
    Technical knowledge from the following:
    Steve Slocombe: Buying, restoring, and riding a VL
    Perry Ruiter Diaphragm Horn Overhaul Procedure
    Bruce Palmer: How to Restore your Harley Davidson
  • koanes
    • Apr 2003
    • 656
    Nicely done Joe. Thanks for putting all that up.
    Kyle Oanes AMCA # 3046
      • 6008
      Like Kyle said, very well done Joe. Your pictures are excellent and really convey the process. I've got to get a better camera.
      • slingshot
        • Nov 2014
        • 3
        Hi Joe,
        Thanks a lot for sharing your experience and learning's. It's surely going to be of help to a lot of us.
        Regards,
        Manjeet
        • Magic
          Magic
          • Dec 2002
          • 282
          Very nice well done Illustration of the Horn project. That's why we cover them during washings :-)
            Nice report, thank you. As it's a VL horn I have a few comments on finish. The face should be chrome of course, and the diaphragm and tone disc silver to simulate their original finish. There is also one small spacer plate missing either side in the photo of the mounting kit.
            • Joseph.Greiner
              • Mar 2014
              • 16
              Thank you all. I didn't know the disc and diaphragm were supposed to be silver, and I wasn't sure if I was missing anything from the mount; thank you very much. I am debating on getting the cover refinished, since it is a steel cover I was thinking about leaving it as is until I am ready to start searching for a brass cover
              • frichie68
                Senior Discount
                • Apr 2012
                • 646
                Old thread-Thanks for the help!
                Rich Inmate #7084
                • JStafford
                  • Dec 2025
                  • 11
                  I know this is an old thread but my search for answers has gotten me nowhere. Steve’s description of finishes on a VL horn is as close as I have come.
                  So here’s my issue: I have a 4801-42 horn going on my high vin (late) ‘46 F. I know the body is black and the face is chrome. I have a brass/chrome face and a steel/painted face. I’m using the latter just because I like the look better than the chrome one. Also, I’ve come to realize that “early” and “late” in ‘46 can be a blurry line.
                  Anyway, does anyone know what the finishes are on the internal parts? Meaning the diaphragm, tone disc and reinforcement ring?
                  I have a hunch that they should be cad plated. But I’m usually wrong about everything so….
                  Thanks everyone!
                    The 1947 dealer announcement of 07 October 1946 says 'In all our 44 years of manufacturing history we have never passed through a period beset with greater difficulties than those which were experienced since VJ day'. The company had a six week labor strike late in 1945, leading to a combined Oct/Nov Enthusiast magazine for the first time in twenty years. There is no 1946 sales brochure or new model Enthusiast magazine. The May 1946 Enthusiast says 'The great demand for new Harley-Davidsons far exceeds our production capacity. As a result we have been compelled to ration our motorcycles to dealers and put them on a quota basis.' The military inspectors for the WLA/WLC contracts would have left the factory, materials were rationed by the Government, but GIs were coming home with money in their pockets and Harley could sell everything it could make. On the technical side, the headstock angle, forks and handlebars were changed early in the 1946 model run, with the wider mudguard braces introduced later and some bikes seen with one narrow and one broad fender brace. Stainless strips are seen on the tanks early in the season, with the fender strips added later. No footboard rubbers, plastic handgrips and synthetic tires will have been seen until the regular parts became available. I'd stay with the black painted steel horn face, with the internal horn parts finished as the late WLAs, but others may have better information. I don't see any record of engine numbers where these many changes were made so the AMCA judges should not give you a hard time.
                    • JStafford
                      • Dec 2025
                      • 11
                      Thank you Steve!
