Work stand for 1934 VL
  • leomags
    • Dec 2008
    • 46
    What can I make or buy that will serve as a stand to hold the frame of a VL while I put everything back together?
    Install the rear stand on the frame and put it down. Install the forward footboard support rod into the frame and place a jackstand on each side if it. Your bike is now in a secure position to work on.
    • leomags
      • Dec 2008
      • 46
      Thanks for the tip.
      • Ohio-Rider
        Supporting Member
        • 852
        Not really related but I’m curious if putting a bike on the rear stand was meant to be a one man operation? Is there a technique to doing it? Or am I really that out of shape?
        Steve
        AMCA #7300
          Stand behind the bike and pull it up onto the stand. Takes a little getting used to.
          • Mark Woodstock
            • Mar 2008
            • 24
            Once you have the rear wheel or rear stand on, you can put the foot board shaft through the front frame loop and sit 2 axle stands under it. Seems to work great.
