Home Made Brake Rivet Tool
  • Holeshotbob
    • Feb 2017
    • 76
    AD353589-4334-42C3-B6D9-1F8AE9C8E6B3.jpeg I thought I would share this little brake rivet tool I put together to do the brake lining rivets on my Knucklehead. I purchased the proper size rivet setter from Hanson Rivet. I took a cheap Chinese 3” c-clamp, removed the threaded clamping auger and drilled out the hole in the body of the clamp to a size that allowed the rivet setter to insert. I then took a small bit or round stock sized to match the rivet head size, cut that to a size that allowed for proper positioning of the lining and shoe under the rivet setter, and welded the small piece or found stock in place. I tried it out and it worked great. Total cost was zero since I had the clamp and round stock, but even if you had to buy the needed items, it should be under $10, and took about a half hour to make. D5A7A3B7-406E-42F5-AC29-85B1B2CCBC40.jpeg
    • 4790
    Great tool!!
    • snafalton
      • Apr 2005
      • 19
      Well done! Excellent idea!!
      • larry
        • May 2009
        • 247
        Clever idea
        • PaulCDF
          • Aug 2019
          • 1433
          Nice I'll have to check out Hanson Rivet!
          • craig (DE)
            • Oct 2010
            • 344
            Great idea! I might have to copy your invention.
            Craig (Delaware)
            Delaware Bay Chapter
            Perkiomen Chapter
            AMCA Member #1011
            • wallaman
              • Jul 2020
              • 92
              Bob,
              GREAT tool! Looked at the Hanson site and not sure what "rivet setter" you ordered. Got a specific name or part #?
              Thanks.
              Chuck S.
              • Holeshotbob
                • Feb 2017
                • 76
                They actually call it a “clincher.” Here is a pic.
                • wallaman
                  • Jul 2020
                  • 92
                  PERFECT!
                  Thanks.
                  Chuck S.
                    • 6034
                    It really pays to have a look at older posts as I missed this post somehow. I was just thinking about making a rivet setter for brake shoe linings. Holeshotbob's fixture looks perfect. Thanks for the pictures, and description.
                    • joe fxs fxr
                      • Dec 2020
                      • 702
                      Thanks for bringing this back to the surface. I saved the pictures in my 71/72 Ironhead folder
                      AMCA #41287
                      1971 Sprint SS350 project
                      1972 FX Boattail Night Train
                      1972 Sportster project
                      1973 HD Golf Cart project
                      1989 Springer Softail project
                      2020 Heritage Classic 114
                        • 2044
                        If you have 3 hands,that would work as well as the foot operated riveters from long ago.
                        They have the advantage of pushing the rivet & lining tight to the shoe before setting the rivets.
                          They still exist, Duffey!
                          The only improvement I would suggest for HoleShotBob would be to make it a screw-press, and spare the hammer.
                            • 2044
                            Cotton,mine has the drive for arcing the shoes.
                              Mine is fossilized in the attic somewhere, minus the motor, Duffey!
                              But I've got pics of a good one, probably yours.
                              Speaking of arcing shoes...
                              .....Cotten
