Help with torque value
  • dthomas1948
    • Jun 2026
    • 2
    Hi my name is Dave, my wife and I have recently inherited a 48 Indian Chief basket case, that was my wife grandfathers, it was missing the rear wheel, I have purchased a repo hub and wheel and spokes from kiwi. I have the wheel laced but I need the torque value for the nipples. Please advise.
    • 6041
    I do all of my wheels from bicycles to motorcycles, off-set, and strait-laced. Torque values would be extremely difficult to quantify because there are many variables to consider. Trueness of rims, spoke quality, and off-set values that Indian wheels have due to spoke lengths, etc. I have just finished putting my 1941 Indian Sport Scout together and the wheels for it are unique because there are 4 unique spoke configurations for the 2 wheels. I say that because it is the worst case for wheel lacing and truing; but, the Scout make my point that each wheel must be laced and true to the fork, or rear frame section. So, I true wheels to the fork or frame the wheels are actually going to run in. I don't go by off-sets from a factory specification because frames get wanged, bent, and fatigued, and fenders can be all over the place for obvious reasons. You can do your wheels any way you want, but at the end of the day, you want your wheel and tire to be in the center of your frame, and fender. 1948 Indian factory off-set wheel specifications are based on frames, forks, and fenders that are within manufactured specs that are now 78 years old providing the bike has not been in a wreck or abused.
    As for spoke nipple torque; that is an intuitive feel that you will get as you go round, and round on the wheel. You will tighten some spokes, and loosen opposite spokes to achieve trueness, and then you will compensate surrounding spokes as needed. That is a feel you will sneak up on. Start out with even turns on the nipples and constantly rotate the wheel to find high, and non-concentric spots by using a marker pen. You don't have to be precise at the start; just get in the ballpark and then refine your adjustments to whatever precision standard you want to achieve.
    I hope this doesn't sound too snooty, or condescending. This is how I do wheel lacing and truing and I have found that it is less of a science, and more of a 'feel', but God forbid, don't half-ass it because your life depends on the wheels under you !
      Welcome, Dave!
      Measuring the torque applied would be a trick in itself.
      As Eric points out, the rim is the prime variable, and the rest is an art;
      I was never very good at it (I hated it), so I relied upon gently striking spokes with the wrench to hear hear the notes they produced, to then locate slack or stressed individuals or groups.
      PS:
      It goes without saying, you will always need one more tool..
      • PaulCDF
        • Aug 2019
        • 1435
        "Help with torque value"
        WELCOME DAVID!
        Here is a link to a previous post on this topic (THANK YOU Harry Robers):
        forum.antiquemotorcycle.org/bboard/forum/technical-discussions-indian/chief/327088-lacing-16-chief-wheels#post327228
        I did this ONCE on my 741 rims after reading manual and watching a DVD on topic.
        [Spritz by Fritz Lace & True A Motorcycle Wheel]
        I used a dial gauge which as Cotten indicated made it WAY EASIER than trying to use a 'pointer'
        Hmm my 'link' to Harrys post does not seem to work. Just enter search term "wheel lacing" in the search box and you will find it.
        Just take your time and be patient.
          I've been scratching my head and chin all night, Dave.
          How have you measured the torque applied to spoke nipples?
          A spring scale and calculator?
          Thanks in advance,
            • 6041
            Lo and behold, I came across this picture today in my Honda 450 manual. I just got my 450 out of suspended animation this week and have been having a lot of fun reconnecting with where I was at 7 years ago when I parked the little guy. I actually re-laced and trued the wheels on my 450. . . Well, just because; but I didn't do what this picture shows, and I'll bet that the wheel assemblers in Japan did not use a torque wrench when they were putting wheels together.
            • dthomas1948
              • Jun 2026
              • 2
              Hi guys, thanks for your help. I do have a nipple torque wrench that I got on Amazon, it has metric adaptors, so I ground one that was slightly smaller to fit the nipples, its 30 to150 inch pounds. My wife did find on google that the torque is 35 to 45. I still need to clean up the brake drum, and install the new drum bearing, the hub came with the non-brake side bearing installed. I do have a dial indicator and a wheel stand, I think that I will try to get it trued on the stand, then when I get my shocks rebuilt, put it on the bike and check it for true. Just a little about myself, I am 72, I have been a mechanic since I went in the MARINE CORPS when I was 17, I worked on F4 Phantoms, and AV8 Harriers. I have built two Harley clone choppers from the ground up, on the second I made the springer, tank, handle bars, and other parts in my shop, I have just never done a wheel & spokes
                • 6041
                Welcome, Dave!
                PS:
                We had a family dog that had the same coloring, and beautiful, loving face as your dog, Tom. We were told she was half (?) Labrador, and we speculated half (or mostly) traveling man. Great dog, but aren't they all.
                • dukekleman
                  • Jul 2022
                  • 597
                  DThomas1948,
                  I have a torque wrench manufactured by Excel made for torquing spokes.
                  I have used it for over 25 years now. I do a lot of wheel lacing between shop service and instructional.
                  I find the range will go from 30 in lbs to as high as 80 in lbs.
                  It varies based on the spoke diameter, thread engagement length, coating , material it's made from and lubrication.
                  The values you've stated of 35-45 in lbs should likely work well for your wheel.
                  I'm glad to see you are looking to torque your spokes, I feel it's very important based off my years of experience. Future maintenance monitoring the torque is very critical as the wheel is put into service and the nesting process begins.
                  I hope this helps,
                  Duke Kleman
                    Eric's Honda pic in #6 makes perfect sense to me, Folks!
                    Particularly since its a true torsion wrench, and not a clicker.
                    But I would still have to weld up an extention from a conventional 'tool-bag' spoke wrench, as open-end wrenches that small would be just as sacrificial.
                    And we want to marr the nipple as little as possible.
                    PS:
                    The precious old bitch in the pic might have been a 'border-lab', Eric..
                    A pit bull took her out, but I don't blame the breed.
                    • PaulCDF
                      • Aug 2019
                      • 1435
                      Then there is this from Buchanans wheels and spokes:
                      :"Our custom made Torque Wrench Nipple Adapter is designed to fit your 1/4" socket drive beam style torque
                      wrench, changing it to an open ended torque wrench. It is adjustable to fit nipple flats from .180" to .343",
                      and is intended for checking spoke tension only. It is not recommended to be used for truing wheels.
                      PLEASE NOTE: Read-out will be approximately 6 in/lbs low. Add +6 to the read-out for better accuracy."
                      List price $35.00 at time of this posting.
