Old member returning
  • Scooter6
    • May 2025
    • 31
    Good evening,
    I am old member been away for 20 years spending time with family and now I have more time to myself again. I am getting back to an Excelsior engine project I have been trying to build from parts for the last 30 years.
    I see some people I have communicated with in the past are still active and I am looking forward to interacting again.
    Scooter
  • JoJo357
    • Feb 2016
    • 3307
    Welcome Scott. It's never to late to hop on the wheels again. Looking forward to your Excelsior project. *Good Luck!
    *M.A.D.*
    • PaulCDF
      • Aug 2019
      • 1435
      Welcome Back!!!!
      • Scooter6
        • May 2025
        • 31
        Good afternoon,
        Thank you for the replies. I am wondering if there is a way to receive notifications by e-mail? I have not found that.
        Please let me know if you know.
        Thank you,
        Scooter
        • PaulCDF
          • Aug 2019
          • 1435
          "I am wondering if there is a way to receive notifications by e-mail? "
          I know if someone quotes you an email is generated. Other than that I plead ignorance.
          • JoJo357
            • Feb 2016
            • 3307
            Originally posted by Scooter6 View Post
            Good afternoon,
            Thank you,
            Scooter
            Scott, describe the Notification you wish to receive.
            *M.A.D.*
            • Saddletramp
              New Old Member
              • Aug 2011
              • 130
              Welcome back Scoot. I can't help but think that if I was building a pre- 36, I would hold more sway in this forum than a meager Panhead builder. None the less, I love you RubOne. Less we are, but not forgotten. Finishing the '60 is kicking my ass for monetary and other reasons. But it was my first. So I shall endeavor to persevere.
              Then comes the next one. Thanks all of you. I wish I'd been active in this AMCA since I joined.
              • Scooter6
                • May 2025
                • 31
                Good morning,
                Email notifications started showing up yesterday morning blocked as SPAM and I will try to get worked out. At least they are arriving. So for though they all have quotes as PaulCDF mentioned.
                The type of notification was asking about is if someone replies to one of my posts like this "welcome" or I have a want ad and a post in the technical section. I did click subscribe on all of these, but have not receive a reply to my other two posts yet to know.
                Thank you,
                Scooter
                • micmac
                  • Feb 2009
                  • 468
                  Welcome Home Scooter6
                  Pete Cole AMCA #14441
                  1947 Indian Chief
                  • Scooter6
                    • May 2025
                    • 31
                    Good evening,
                    wanted to let you know that I did receive an email notification from micmac that did not include a quote, so I think the email notices are working like I was wanting. Just wish I would get one to sell me a cam cover and crank pin.
                    Thank you,
                    Scooter
                    • gharper
                      • Nov 2009
                      • 528
                      Welcome back Scooter6.
                      If you're trying to piece a Series 20 together, that's a tough job! X parts have virtually dried up. Not that they were plentiful but over the last 35 years, I've pieced together 6 different versions of 16-24 Big X "kits". I've sold all but 2 and virtually all my spare parts. Do your homework, start at the AMCA virtual library, a few X sales brochures there.
                      1915 Big X is a one year timing cover with 1 hole and a pronounced bump in the raised cam and lifter area. Series 16-19 are the same, with only 1 hole for the cam support shaft to protrude, and then a nut. The area over the cam and followers is raised, but flat. Series 20-24 is the same as 16-19 other than it has 3 holes. The other 2 holes are for the cam follower shafts to protrude through the cover, again held with a nut. Sorry, I don't have a timing cover. If you have a Series 20 motor, it should have the threaded cam follower shafts. Some earlier motors were converted to three threaded shafts and the cover drilled to fit. So, if you can find a 16-19 cover, it can simply be drilled to fit the longer, threaded shafts. Beware, don't just bore it out, it needs to be a shouldered hole to support the end of the shaft.
                      15-24 crank pins are the same, pre 15 are shorter. I may have a used one that may be decent enough for minimal use, it was running when it stopped! No oil holes in the pin, splash only. Unless someone messed with the wheels, 14 was the only year the wheel was drilled for oil, same with the pin. Yes, 2 thrust washers on the rods, one each side. Also 1 thrust washer on the drive side flywheel only.
                      • Scooter6
                        • May 2025
                        • 31
                        Good evening,
                        Thank you very much for taking the time to give me the technical information. It has been years, but I believe you are the person who helped me years ago and identified that my engine had an adapter on the intake making it bigger and I had a big valve intake that you traded for some much needed parts that got me further.
                        I finally brought myself to carefully remove the adapter to find the original threads intact and the braze was just to hold it in place. I will post pictures in the technical question I posted.
                        I will very much appreciate if you look to see if you do have a crank pin to sell me. If you find it, I will PM you my contact information to figure total with shipping.
                        Thank you,
                        Scooter
                        • gharper
                          • Nov 2009
                          • 528
                          Indeed, I recall getting the manifold from you. The nuts and manifold had been shortened a bit so so I didn't use that one, it went elsewhere in a trade. You can call me at: 720-341-5606.
                          • Scooter6
                            • May 2025
                            • 31
                            Good afternoon,
                            Great to speak with you. Thank you for you time.
                            Scooter
