1947 Knucklehead
  • oldblu
    • Dec 2018
    • 17
    1947 Knucklehead
    Hi, new to the forum but not to old bikes. Restoring a late 1947 straight leg Knuckle and I am attempting to use the correct tool box mounting bracket 47386-41 does it take the three hole bracket or two hole is it mounted with bolts or welded? I would prefer someone who has and original late 47. Thanks oldblu.
    • oldblu
      • Dec 2018
      • 17
      Chris: I have had Palmer's for many moon's and i have seen original 47's with the tool mount up high and low just attempting to find out what is the majority. Much thanks. oldblu.
      • 55tmm
        • Dec 2009
        • 158
        oldblu,
        Mine is mounted low because of the Loctite bags, which I'm told is correct.
        • oldblu
          • Dec 2018
          • 17
          55tmm: thanks for the very informative information, i will be putting loctite bags on mine as well, does yours have a two hole or three hole horizontal bracket and is it welded on or bolted on and hoping you have a late xe-12 frame. this would be most helpful. Thanks again oldblu.
          • 55tmm
            • Dec 2009
            • 158
            oldblu,
            The horizontal bracket on mine has 2 holes and is bolted on low, original paint and shows no sign that it was ever mounted to the upper position which has 3 holes in the vertical bracket. My vin is 5_ _ _ _ with early seat and bags, frame has 11 on it.
