Nickel Plating
  • cycarmark
    • Aug 2023
    • 20
    Nickel Plating
    I have a full bike worth of nuts, bolts, hardware, brackets, etc. that need to be nickel plated. The place that I've used for many years is closing so I need a new place to send them. Any recommendations?
    Thanks!
  • PaulCDF
    • Aug 2019
    • 1422
    Mark: Where are you located?
    • cycarmark
      • Aug 2023
      • 20
      Tallahassee, Florida. Here's a picture of the parts.
      This gallery has 1 photos.
      • chuckthebeatertruck
        • Jun 2018
        • 693
        Quality Plating, Quincy, Illinois
        That said . . .nickle is just as expensive as chrome -- but YOU can do nickle at home without much trouble.
        I literally used up a Caswell Nickle plating kit -- did four full bikes. I still ride one regularly and 15 years later -- the nickle has turned soft and buttery colored; just like old nickle should. It's really quite, quite simple to nickle plate.
          • 6018
          As Steve said above, the Caswell electroless nickel kit works very well and actually is kind of fun to use. Cleanliness is paramount for a successful job. My 1919 Henderson has Caswell nickel plating I did over 20 years ago still looking good. When it does dull with age, a bit of polishing with Mother's mag & wheel polish will bring it right back. Nickel is a wicked tough metal.
          • cycarmark
            • Aug 2023
            • 20
            Thanks guys, I've got the Caswell nickel kit (not the electroless) and it is nice but would not be good for lots of parts. The electroless looks a lot easier.
              • 6018
              Electroless is much easier, and safer. Looking at your pile of parts, Mark you would have a bit of prep work ahead; but the time, money, and anxiety of shipping costs, and parts loss from going with the pros could well off-set your own effort.
              • cycarmark
                • Aug 2023
                • 20
                Not losing parts is the most critical thing. The plater I had used only lost one part in 16 restorations. Luckily it was a fairly easy to replace item.
