Guide Passing Lamps Bent Bolts Fix - 64 FLH
  • Iacovos
    • May 2012
    • 208
    Hey everyone
    Just discovered this on both passing lamp shells
    Do you know anyone that can fix these? Or are they fixable in any way?
    As i can see the bolt is secured in with tabs
    looking forward to your assistance as i got stuck again
    Thanks for your feedback in advance
  • BigLakeBob
    • 2767
    I've found them pretty easy to fix and bend because of the hole in the middle. My method, find a piece of tubing or pipe that fits pretty good on the thread OD. Heat the area where it needs bent and bend away. They don't need to be perfect because of the multiple swivel washer setup. My opinion.
    Bob Rice #6738
      • 4789
      If you straighten them be sure you use all the correct hardware to mount them or they will just bend again, and likely break at the bend.
      • Iacovos
        • May 2012
        • 208
        Thanks Rubone and BigLakeBob for the pointers
        Will surely give it a try and hopefully fix both of them
        Will also check in the parts catalogue if the hardware i got here are correct.
        • Iacovos
          • May 2012
          • 208
          Rubone this is the hardware i have (number 27 is x 2 and number 33 adapter bushing is not used)
          Looks ok right?
