Oil pressure switch wire clip
  • Omarttentmaker
    • Dec 2009
    • 322
    Anybody know of any vendor that's offering this part? Knuckle parts book lists it as 1520-48E. Panhead parts book lists it as 9913.
    • 2044
    The correct part probably depends on the year you are doing.Later number may be a different design.Quick search online shows vendors offering different parts.
    • Omarttentmaker
      • Dec 2009
      • 322
      I tried a search using both part numbers but came up blank. How did you search?
        • 2044
        Harley 1520-48E, sent me to Cimmaron Cycles..What year?
        • Omarttentmaker
          • Dec 2009
          • 322
          1949 or 1955
            • 2044
            I don't know if this is correct...1 NOS OEM Harley Davidson Female Large Spade 14-16 Wire Terminal P/N 9913 | eBay
              • 2044
              I think you should have an eyelet terminal,not flag.The '49 should have a dome top pressure switch & '55 should have a flat top switch,both with eyelet terminals
              • Omarttentmaker
                • Dec 2009
                • 322
                That's the female clip for a spade terminal.
                • Omarttentmaker
                  • Dec 2009
                  • 322
                  The '49 top is domed, the '55 top is flat. the picture is of a '38. And I was told that the only terminals at the oil pressure switch that were screwed on were military bikes.
                    • 2044
                    Look in your book at wires.
                    You need 9905
                    • Omarttentmaker
                      • Dec 2009
                      • 322
                      You need 9905
                      Just saw it myself. I don't know where I got the other 4 digit number from!
