32E Generator Repair/Restoration
    • 5951
    Rebuilding VS Restoring. Who does the best restoration? Not only working well but looking like NOS?
      • 8234
      Restoration VS Conservation is one step higher.
      PS: I can bring 'cores' to Davenport...
      • BigLakeBob
        • 2767
        Originally posted by gitguy View Post
        I would be interested t know more about Paul Benassi's electronic voltage regulators. Does he have a web page another way to reach him?
        Thanks!
        Hi all, fyi, I developed a very robust Regulator as an embedded solution, it means, that unit we can install in any original DelcoRemy cutout relay housing/chassis.
        It's available for 6 or 12 Volt and is designed up to 150 Watt, 20 Amp. at 6 Volt no problem, e.g. for police generators necessary. Also, I've LEDs for headlamps
        available, they need only 8 Watt and have 1600 lumens. Install it instead your filament bulb, no additional electronic necessary. If you are intarested give me a PM.
        George AMCA 2781
        3 Photos
        The above was copied from a 9/22/21 post 6V LED Conversion. Contact George and he can get you in touch with Paul, they work together. Their units will fit inside any original voltage regulator or cutout housing. I have about 9k miles on one on my pan, it is a 12v housed in an original 6v regulator shell. It is sealed with the original gasket so it does not get wet. Very happy with their product.
        Bob Rice #6738
          • 6018
          Chris, my 32E was rebuilt by Rich Brown (in our magazine). Worked fine, and looks very good. I supplied my painted end cover, and I wanted to keep the original riveted on tag so that is on me. I need to go with the source BigLakeBob cited for a modern cut-out, and LED lights sounds like a brilliant (groan) idea.
          • Austy
            • 41
            Dale did an awesome job with my 32E Generator. Service was fast and very reasonable in price. If it last as long as the last 1 he did for me someone else will be riding my bike. I wanted the original tag left as is so that is on me. Thank you Dale 32 E Generator (3).jpg 32 E Generator (4).jpg 32 E Generator (2).jpg
            This gallery has 3 photos.
            • The_Muzz70
              • Jul 2025
              • 1
              Does anyone have a recommendation for someone who still repairs 6V 32E generator? Much appreciated!
                • 2022
                Thanks!
                Ralph Smith (952) 994-7594
                • len dowe
                  • Oct 2002
                  • 520
                  Try Rob Nussbaum at Retrocycle.
                  AMCA #765
