Ignition Switch Repair
  • otis71
    • Jul 2015
    • 597
    Any ideas who repairs Harley-Davidson ignition switches?
  • tgarcia
    • Jan 2023
    • 116
    What is wrong with it? They are really pretty simple all things considered.
      • 8239
      Usually, Otis,...
      You just need a pair of needlenose to turn the contact bar to where it isn't worn.
      (Be glad it isn't an Indian.)
      • otis71
        • Jul 2015
        • 597
        The contacts are in good shape and clean, replaced the contact bar with an nos oem one but the headlight position has a bad spot and the light goes out. The switch has signs of the wrong hands being on it at one point and is loose on the phonelic base above the contacts. Also the tumbler will turn but not lock out which is secondary.
        • otis71
          • Jul 2015
          • 597
          Looking at it closely now. The phonelic base is damaged.
            • 4789
            Check with Bill's in PA, he had lots of OEM phenolic contact rings on eBay in the past.
            • ammorest
              • Sep 2008
              • 301
              Depending on year there are two different contact plates; 5 terminal and 6 terminal. Terry Marsh was rebuilding switches, not sure if he is still doing it. You can send him an email . marsh1915hd@msn.com
              Dave
              • 1937hd
                • Nov 2016
                • 62
                I can repair ignition switches I have lots of parts for them.
                • otis71
                  • Jul 2015
                  • 597
                  I found the nos parts on I hate to say eBay and repaired it myself. Thanks for the offer.
