rubber peddle block for a 15 Indian
  • john fretschl
    • Aug 2006
    • 73
    any vendor reproducing a rubber peddle block for a 15 Indian kicker??
    • 6028
    Can you post a picture, John. I have some spare pedal blocks and may have what you need.
    • john fretschl
      • Aug 2006
      • 73
      Mine is missing. will look for a pic in the net. I know the length and Dia. of the center hole, most likely
      will need a sleeve pressed in. Looks to be much bigger than the biggest bike peddle.
      • HDSmitty
        • Jul 2017
        • 282
        PEDAL !! NOT peddle, which is to sell or market something. Sorry....it was for some reason just bugging me. Thanks :) Smitty
          • 1675
          John, not sure what's the correct rubber, but Walker Machine carries one they list as "Hedstrom and PowerPlus"
          • john fretschl
            • Aug 2006
            • 73
            If it fits a Power Plus it should fit a 15 kicker. Have to check their web site and find the whole dia.. Thanks for the lead.. Looks correct. factory drawing shows that diamond pattern.
              • 6028
              I have a 'diamond' type pedal block, but it's not like the one pisten-bully so kindly posted. Sounds like Walker is your best bet, John. I do know that genuine rubber pedal blocks from 100 years ago don't hold up very well, so you're better off with a reproduction.
