oil pump drive gears upgrade
  • Omarttentmaker
    • Dec 2009
    • 322
    Looking to put the bigger oil pump drive gears in a '52 FL motor. H-D doesn't make them any more. Does anyone know an after-market manufacturer who does? I know they come as a pair, one that goes on the pinion shaft, and one that goes on the oil pump shaft that's in the timing cavity. Any help greatly appreciated.....Cheers.....Omar
  • kitabel
    • Sep 2018
    • 471
    They're not bigger, they turn the pump faster.
    IIRC S&S does
    The Linkert Book
      • 4791
      The gears were never made for a splined shaft by H-D. They only made them from the early '70s up but due to the shaft design they fit back to '54 ( or earlier if the shaft, case race, pinion gear, rollers, etc were also changed). Splined versions were always aftermarket.
      • Omarttentmaker
        • Dec 2009
        • 322
        Got it now. Saw the replacement stuff in the s&s catalog. thanks for the input.
        • kitabel
          • Sep 2018
          • 471
          More information on oil pumps on my site: http://victorylibrary.com/tech/OHV-pump.htm
          The Linkert Book
          • Omarttentmaker
            • Dec 2009
            • 322
            Hey, kitabel, who is IIRC? Bought the upgrade oil pump drive gears from S&S, and the one that goes on the pinion shaft is too small to fit on the shaft. From what I can measure, the shaft is .848" over the splines, but the gear is .843" (.005" interference!!!!) Typed in IIRC to do an internet search and didn't get anything m/c related.
              • 4791
              IIRC is a slang acronym for "if I recall correctly".
              • kitabel
                • Sep 2018
                • 471
                This is the first I've heard of S&S having a "JIM'S" problem (looks good, can't fit w/o major work).
                Is S&S now pronounced "Beijing"?
                The Linkert Book
                • Omarttentmaker
                  • Dec 2009
                  • 322
                  LOL. I'm not all that hip to internet jargon!
                  • Omarttentmaker
                    • Dec 2009
                    • 322
                    Talked to the shop I bought the parts from. He said he'd contact s&s tomorrow. I told him to send the pics of the measurements I took. I doubt it'll do any good. Will keep everybody posted on this snafu.
                    • Omarttentmaker
                      • Dec 2009
                      • 322
                      I have been enlightened by the panhead manual. On page 170 there is information re/ an upgraded pinion shaft that was introduced in late '51. This shaft is larger in diameter so that the pinion gear is a press fit on the shaft. The press can be up to .002", according to what I read. That means that the inner splines on the oil gear that goes on the shaft would have to be bigger, as I am sure that it is not a press fit. A special tool is required to remove and install the pinion gear, but no mention is made of the oil pump drive gear. I know this is the upgraded pinion shaft because it has a screw in its end. So when s&s advertises the oil pump drive gear update, it's actually misleading. It should read '39- late '51. The gear for those models will not fit on late '51-'53 motors. Of course, my confusion is only compounded by the fact that the pinion gear that came off is a slip fit on the shaft. Don't know if that's due to wear, or if somewhere along the way it was reworked to be a slip fit on the upgraded shaft. FYI.
