HELP ID rear double band style brake looks early????
  • DEWGARINC
    • May 2005
    • 69
    anyone know what this is ?year make model??? THANKS
  • Paps
    • Jun 2003
    • 1814
    Just guessing but my first thought was early servicar. Paps
    • Tommo
      • Sep 2001
      • 1321
      Looks Excelsior to me.
      1915 and earlier were different from the 1916 on ones but it will take an Excelsior expert and not me to tell you exactly what you have.
      Peter Thomson, a.k.a. Tommo
      A.M.C.A. # 2777
      • Rod K
        • May 2006
        • 179
        I believe the inner brake is an expanding band and the outer is a contracting band. I had a 1921 Indian with a brake set up very similiar to this one. The foot brake worked the inner and the hand brake worked the outer band on the outside of the brake drum. Can't say for 100% certain,
        but thats my guess........Rod
        • Duda
          Duda
          • Nov 2001
          • 84
          I have a 1917 HD with that rear brake. The external brake had a lever on the right side of the handlebars. The few I have seen place the lever on the left side. Its nice having an extra brake but its still not much. I use it when I am stopped and want to hold the bike in place. I can send a few photos if you want.
            • Feb 2003
            • 5353
            It also looks a lot like the brake that a '16 Powerplus should have. I have a pretty rough copy of the parts book and an attempt at a scan turned out too poor to post but it sure looks close. A friend sent me this pic and it appears to be similar. I'm thinking it's a good chance that quite a few companies used this brake.
            Cory Othen
            Membership#10953
            • kval
              • Jul 2001
              • 508
              that looks like the brake used on export models, they called for two brakes and american bikes only had rear brakes. they just added another system to the existing rear brake, great for sidecar use. have a friend with a 25 Chief and Flexi sidecar with this setup
              Kevin Valentine 13
              EX-Chief Judge
