Sidecar/Servicar jockey section
This topic is closed.
  • Chuck#1848
    • Oct 2004
    • 920
    Hi guys,
    Although I can only imagine what it must take to put a web site together with all the changes and security measures these days we will still see a Sidecar/Servicar section?
    Thanks,Chuck
    Chuck
    AMCA Member#1848
    • 5954
    What is a jockey section? How to convert your bike from a tank shift, safety clutch to a jockey shift, suicide clutch section?
    • Chuck#1848
      • Oct 2004
      • 920
      Chris,
      Noooooooo..........it refers to the person,rider of said mode of transportation be it a sidecar,servicar or both, what you are refering to has nothing to do with it although it is possiable that a Jockey in question could prefer a suicide clutch........
      Chuck
      AMCA Member#1848
        • 5954
        I thought sidecar passengers were called monkeys.
        • Chuck#1848
          • Oct 2004
          • 920
          Technically it's the racing passangers are the ones that are refered to monkeys, due to their moving and climing around as the sidecar rig manuvers around the race course basicly they are human ballast leaning over the rear tire of the bike to help keep the rear wheel down and in contact with the road surface.
          And then leaning out beyound the sidecar wheel and low to the ground sometimes inches from the pavement surface for the same reason to keep the sidecar down when entering the turn.
          As far as I know, the driver is the one that is refered to as a Sidecarist, Sidecar Jockey,Hacker or Hack rider ;D
          Now,I have never have heard of a Servicar rider called a Jockey before I figured I would just throw that in there even if both of their rear tires are in line ,Should you be interested There is some sidecar racing coming up in Southern Ontairo next month
          Although it looks like fun,I always thought that the monkeys had a death wish
          Chuck
          AMCA Member#1848
          • kval
            • Jul 2001
            • 508
            Originally posted by Chuck#1848 View Post
            Hi guys,
            Thanks,Chuck
            Chuck
            the answer is YES, it is coming soon
            Kevin Valentine 13
            EX-Chief Judge
            • Admin
              Administrator
              • Jan 2008
              • 12
              The "Sidecar and Three Wheelers" forum has now been added to the "Other Manufacturers" section.
