Orient / Orient Aster
  • silentgreyfello
    • Nov 2006
    • 861
    I would like to network with others that have 1899-1904 Orient motorcycles. I am going to be making some parts, but don't want to if somebody else has already done so. I would also like to find out how to differentiate between years based on serial numbers, especially the Aster motors.
    thanks,
    oldmtrcyc@msn.com
    Mike Parti has an Orient.
    • silentgreyfello
      • Nov 2006
      • 861
      Thank you. I looked at Mike's bike several years ago. I think someone made the frame at some point, as it is the only Orient that I have ever seen with the motor mounted completely vertical instead of tilted slightly forward at the top. It is still a neat piece, though.
        • Feb 2003
        • 5353
        I believe Pete Gagan has or at least had one. I'm pretty sure I saw one with his name on it at a show a year or two ago.
        Cory Othen
        Membership#10953
        • silentgreyfello
          • Nov 2006
          • 861
          Thanks Cory. I have photos of Pete's when it was being built. Motor is real, everything else is repro. They did a very nice job on it.
          • silentgreyfello
            • Nov 2006
            • 861
            Gagen's Orient
            Here are some pix of Pete's bike when being built. His has the De Dion motor in it, which you could buy a frame and parts from Orient and put your own motor in it, but Orient never produced a complete bike with the De Dion motor, at least according to my research. The first complete Orient's had the Aster motor until 1901, then Orient started producing their own motor. The Aster motor has bronze cases with wafered copper fins on the cylinder. The other thing odd about the Aster motor is that it splits horizontally. The Orient motor retained the copper fins, but went to an aluminum crank case.
            • silentgreyfello
              • Nov 2006
              • 861
              Oops, here are the pix of Gagen's bike
              • Barry Brown
                That guy that builds Gagan's repops is a genius.
                • RichO
                  • Dec 2001
                  • 903
                  Woody Carson
                  I believe Woody Carson also had an Orient he restored while in Europe in the 50's or 60's. I believe there was an article on it in the National magazine.
                  DrSprocket
                  • Pete Gagan
                    • 233
                    DeDions
                    There is a picture of an two wheeled Orient in a late 1899 Scientific American with a DeDion engine, so that was the excuse I needed for mine. DeDions were used in the Orient trikes, and also the Hedstrom Henshaw pacer that was built by Oscar Hedstrom in 1899 while he was working for Waltham Manufacturing, the Orient' builders. My French sources tell me the Aster was only available in one size, 500ccs. Orients were offered in 250cc and 350cc sizes as well, so it is probable the smaller versions were DeDions. Mine is a 250 DeDion and dates from 1899, so is a feasible concept. Some original pieces of the frame were attached.
                    History is, I think, accurately served, but who knows?
                    Pete
                    • 45OZ
                      • Dec 2002
                      • 270
                      thanks,
                      oldmtrcyc@msn.com
                      I always thought that there was only one REAL Orient that is known to remain, If this is so how would you go about getting the proper measurments to produce the parts?
                      The only reason I ask is that I watched a member who has an original Orient Carb that he made repops of & he had to measure all the parts to it to make the forms for the casting.
                      he had explained to me about the shrinkage of the castings so the measure is very crucial to making exact duplicates of the parts. Since the percentage of shrinkage must be compisated for in the mold blank construction.
                      I must say the Orient Carbs he made are absolutly beautiful, & all his repro parts are completly interchangeable with the Original. I was amazed at the amount of time to make the mold blanks, castings & all the machining involved seems like a lot of work for a limited # of machines. Just wondering how it would be done if the proper & exact parts can't be measured or are not available
                      • silentgreyfello
                        • Nov 2006
                        • 861
                        I know of at least 4 complete bikes here in the states, and I have heard of one in the Netherlands. There are some partial bikes out there that could use some parts, and several loose motors.
                        • silentgreyfello
                          • Nov 2006
                          • 861
                          Pete
                          A nice replica. A few things that jump out that are not correct is the front fork casting at the crown, front frame casting (he butted the tubes because he didn't have the castings), and the rear seat stay where the frame goes around the belt. On the original bikes, it was rather squared off instead of gradually sloped like a harley belt drive. Wrong seat (though period correct). I am not picking it apart other than hopefully nobody will copy this bike and then later on there is a debate about what is correct.
                          • 45OZ
                            • Dec 2002
                            • 270
                            Wow thats more than I was aware of, Will you be taking the measurments from them?
                            • silentgreyfello
                              • Nov 2006
                              • 861
                              Yes, I will.
