gummed up gas tank
  • Glenn
    Member to Remember
    • May 2007
    • 403
    gummed up gas tank
    what is the best way to clean a gas tank that has been sitting for 44 years and has gooey molasses type glued to the inside of the tank. the saving factor is there is no rust. going to paint the tanks so that is not a worry.
    has anyone used media blasting
    or what is the favorite chemical route?
    thanks
    moose
    Moose
    aka Glenn
  • 23JDCA 808
    • Jan 2007
    • 688
    I would start with safest, least volatile and cheapest solvent; then work up the list. Do it outside and away from open flame. Try a little bit of paint thinner. If that doesn't work, let it dry out. Then maybe gasoline, and maybe lacquer thinner at the end. There will be other solvents suggested; that's all I could think of. ...bill
    Bill Gilbert in Oregon
    • Ohio-Rider
      Supporting Member
      • 852
      I agree with Bill. Since your painting the tanks later, your free to try anything you can think of. Be sure to do it outside and wear your rubber gloves. I would probably begin by filling the tank about 1/4 of the way with gasoline and add a big handfull of 1/2" flat washers and swish,turn,flip,shake,ratlle and roll. -Steve
      Steve
      AMCA #7300
        Glenn you can also try MEK. At least I think thats how it goes. To say the least this is the only stuff that I found that eats out cream tank liner. I figure if it can eat that stuff. Gummy gas would be an easy chore. Bob
        • Kojack
          • Mar 2003
          • 261
          Just about any carburetor cleaner will dissolve it. Berryman makes a good one that comes in gallon cans. Don't use the aerosol type, it'll evaporate too fast.
            • 6044
            I second Bob's choice of MEK. Great stuff and a super strong solvent. Just don't drink it.
              • 8247
              Shell Premium summer blend will even eat powdercoating.
              (Wear gloves and safety glasses when using it... in a well ventilated area.)
              • Glenn
                Member to Remember
                • May 2007
                • 403
                thanks for the replys
                cotton
                i got your float
                thanks
                Glenn
                Moose
                aka Glenn
                • Glenn
                  Member to Remember
                  • May 2007
                  • 403
                  cotton would you have the spring that goes on the throttle shaft under the throttle cable holder
                  glenn mills
                  Moose
                  aka Glenn
                    • 8247
                    Glenn!
                    My business is a service shop only (I cut floats personally), and I have no wish to conflict with all my friends who run mail-order parts operations.
                    If you do not have a local independent shop to support, try Kick-Start Mcy Parts 616-245-8991
                    Good luck!
                    • Glenn
                      Member to Remember
                      • May 2007
                      • 403
                      thanks
                      glenn
                      Moose
                      aka Glenn
