throttle block height mismatch
  • Omarttentmaker
    • Dec 2009
    • 322
    This is in response to the guy who posted the question about the height mismatch between the throttle cable and the throttle block. I read the post this morning, but when I went back to respond the post had disappeared. I've contacted a site admin about the problem, but in the meantime I thought I'd show this. The pic shows several different throttle lever arms used in different years for different models. I believe the one you want is one of the three that are second from the left in the pic. Note that the tops are all different, and i don't know which one is completely correct for your application. carb linkage risers.jpg
  • C.Flint
    • Dec 2015
    • 49
    Perfect, thanks for sharing.
      Gadfly from the Dumpster
      • 8236
      What about all the rest, Omar?
      .....Cotten
        • 8236
        Wait! There's more,...
        And probably many I didn't record.. And there were at least four different cable blocks.
        .....Cotten
