This is in response to the guy who posted the question about the height mismatch between the throttle cable and the throttle block. I read the post this morning, but when I went back to respond the post had disappeared. I've contacted a site admin about the problem, but in the meantime I thought I'd show this. The pic shows several different throttle lever arms used in different years for different models. I believe the one you want is one of the three that are second from the left in the pic. Note that the tops are all different, and i don't know which one is completely correct for your application. carb linkage risers.jpg
throttle block height mismatch
Tags: None
What about all the rest, Omar?
(20 4012)
DL10 and similar unmarked
DL12
DL54 and DL533?
DL75
.....CottenLast edited by T. Cotten; 11-06-2026, 10:54 AM.AMCA #776
Wait! There's more,...
Most common Indian lever
Mystery lever
And probably many I missed or didn't record; There should be a DC in my tackle box..
And there were at least four different cable blocks.
.....CottenLast edited by T. Cotten; 11-06-2026, 10:51 AM.AMCA #776
