Fender identification help
  • bjind
    • Nov 2005
    • 118
    I can't identify this fender,
    I am thinking Indian, but I have been wrong before, what year and model also
    Thank you in advance
    This gallery has 3 photos.
  • Tom Lovejoy
    • Aug 2006
    • 951
    my bits of Scout has that fender
    • FLFD7
      • Feb 2021
      • 739
      Late 30’s Indian Sport Scout, but somebody messed with the bottom of the braces. The hole on the top center is a clue to the Sport Scout instead of a Chief or Four, there is a mounting screw goes from the inside of the fender to the bottom of the fork body. Here is the fender on my 1939….
      • bjind
        • Nov 2005
        • 118
        Tom Lovejoy, and FLFD7, thank you for the responses
        bjind
        • ChiefTwoKicks
          • Apr 2008
          • 282
          I don't think I've ever seen a front fender (allegedly an Indian scout) with fender stays connecting to the axel, that look like the photos above.
          I could be very wrong, but I was thinking the riveted, widened, and unusual shape of the piece connected at the axel is not Indian, but some other handmade shaped piece. Looks to me like the primer painted fender wouldn't fit well near the front brake backing plate. Also, the flathead screws attaching the fender stays doesn't look correct either... just my 2 cents worth, I'm certainly not qualified to be a judge, but I'm thinking it might be an early Harley fender modified to fit a Scout. Has anyone else ever seen an Indian fender with a bracket like that ? asking for a friend.
          C2K
            • 1676
            ...I agree with C2K, that bracket is likely home built to make the fender fit. The bracket wouldn't fit past (below) the forks on a later 30's Scout, and it wouldn't fit with an earlier leaf spring front either. I also think the hole in the bracket and the angles of the stays appear designed to attach the fender higher up than at an axle, so probably on a rocker.
