soldering copper to steel
  • moritz
    • Jun 2022
    • 60
    is it recommended/acceptable to solder copper to steel nipples with plumbing solder vs silver solder? I don't have silver solder capability currently.......
  • chuckthebeatertruck
    • Jun 2018
    • 697
    it depends on the strength needed, the metals actually being joined, and the cycling the part is subjected to. fitting gap also comes into play.
    ie copper comes in many variety, ditto for steel. some wet better than others.
      • 8247
      I never tried to silver-solder copper, Ken,
      What nipples are you dealing with?
      .....Cotten
      • Kozy
        • Feb 2004
        • 129
        Silver soldering steel to copper is a standard practice in the refrigeration/AC industry.
          • 8247
          My HVAC buddy gave me a bottle of flux a decade ago, Kozy!
          But where on a vintage American motorcycle would you want copper-to-steel so permanent?
          I seriously discourage it for inlet nipples with copper seals.
          • tomfiii
            • Jun 2007
            • 316
            Are you talking about low temperature silver solder?
              • 8247
              My lowest temp silver filler, Tom,..
              Came from RioGrande jewelry supply, forgot the number.
              I still wouldn't use it for anything I would ever want to take apart.
              Soft solder is more friendly, of course!
