exhaust leak problem
  • exhaust leak problem
    Is there any good way to seal the exhaust pipes into the jugs so that they can still be removed at a later date. I seam to be getting a lot of leakage in this area.
    What yr and model of machine? Hi-temp silicone. Copper.
      1935 rld
        rwrun,
        The exhaust pipe should be swaged, or expanded to fit the cylinder. A small tail pipe expander available through Harbor Freight and other sources works well, but work slowly.
        Although not as correct, I have seen some people cut up a beer can and wrap it around the exhaust pipe where it fits into the cylinder.
          I knew I joined this club for a reason. The members here are the best source of information around.
          many thanks
            Good answer Johnny, especially the beer can part.
            Louie
              Try small tin cans, like for mushrooms or tomato paste. The tin ones last much longer than the beer can shims. Works well on Panheads with worn ports!
              VPH-D
