exhaust leak problem
  • rwrun
    Is there any good way to seal the exhaust pipes into the jugs so that they can still be removed at a later date. I seam to be getting a lot of leakage in this area.
    What yr and model of machine? Hi-temp silicone. Copper.
    • rwrun
      1935 rld
      • Johnny
        rwrun,
        The exhaust pipe should be swaged, or expanded to fit the cylinder. A small tail pipe expander available through Harbor Freight and other sources works well, but work slowly.
        Although not as correct, I have seen some people cut up a beer can and wrap it around the exhaust pipe where it fits into the cylinder.
        • rwrun
          I knew I joined this club for a reason. The members here are the best source of information around.
          many thanks
            Good answer Johnny, especially the beer can part.
            Louie
            • VPH-D
              Try small tin cans, like for mushrooms or tomato paste. The tin ones last much longer than the beer can shims. Works well on Panheads with worn ports!
              VPH-D
